First of all, thanks to all the contributors at MVS, and to Robert for the youtube videos, I check the website before I go to any new maintenance item, it have so much information on the 850, and helped me a lot.
We have a 1995 850 N/A sedan, and I've recently acquired a 1996 855T, that I think should be better for the family and more fun to drive.
I am doing a stage 0 and I am trying to bring the car to a reliable condition at a reasonable budget.
Currently replacing the vacuum hoses in the engine bay, most of them are original and in a bad shape.
I want to replace the booster check valve/gasket with the booster hose, (the white, L shaped valve on the booster itself).
Only saw original kit (Volvo - 271632) that goes for 45$ and up. A new ATE booster that include the check valve is ~200$ (ATE 9438036) and even as low as 160$, to me it doesn't make sense to pay ~50$ just for the valve and rubber seal. And I am trying to keep the budget tight, as I don't know what else I'll need before I'll consider the car road worthy.
I searched the web for an ate part number, but to no avail, does anyone know what it is?
Thanks, Yair
Part number for 850 brake booster check valve?
- Has thanked: 2200 times
I'm a little confused on what you are asking for? You mention you need the part number for the check valve and seal, and you have what should be the correct one for -95 850T - 271632.
If you need the part number for the whole Power booster unit it is: 9140234
- yair
- Year and Model: 1997 940 sw
- Been thanked: 3 times
271632 is the Volvo p/n. I am looking for the ate p/n. Afaik this part is made by ate, but I only find the Volvo brand.
yair
1997 940 wagon
2005 XC90
1996 855 Turbo
1995 850 n/a, rest in pieces.
1997 940 wagon
2005 XC90
1996 855 Turbo
thylacine222
- Year and Model: 1995 850 GLT
I know this thread is almost 10 years old at this point, but for the record, the official ATE number is 3.6118-7203.1 which as far as I know you can only get if you buy the entire check valve ($70 at FCP right now). However, ATE 03.7718-7203.1 is the same size and can be purchased from a number of manufacturers (I purchased one for $15 that was the same size from a BMW dealership, just look up the OE numbers for whichever manufacturer listed here on a parts site)
- 11 Replies
- 4366 Views
Last post by warmblood58
- 4738 Views
Last post by SUBdude
- 470 Views
Last post by isaacxii
- 5212 Views
Last post by Botbasher
- 1618 Views
Last post by walter1
