Just finished the PCV repair on our 1996 NA 850 and had hoped that fixing a
vac leak and the PCV would correct the rough running but it did not. I've done
the timing belt, plugs, air filter, cold air flap mod, thermostat, and it does not
report any codes. Compression is good enough in all cylinders. It does not
smoke at all, and the valves looked very clean when I had the intake manifold off.
The PCV was not badly plugged.
I've read:
Disconnect the MAF to rule it out - good idea?
The ECT sensor often goes bad - should I just change it or would we get a code for it?
The O2 sensor often goes bad, it was replaced at 77K now we are at 177K miles.
Any suggestions on how to debug this without throwing parts at it?
I'd like to have an OBDII tester since I work on our other cars also so why not, what
is a good one that will give me the most data and work with other cars? Will it give
me a quick idea of what is wrong?
1996 850 NA Chug Chug Rough Running
- Has thanked: 311 times
- Been thanked: 817 times
MAF: good idea. Car off, unplug it, turn car on, give it a minute to stabilize.
ECT: Pull it out and check it with an ohmmeter at different temps. You can get a chart from the forums (probably in the VRD) with the expected values, it has been posted many times.
If the car has the CEL on, the code reader will help tremendously. Note that your MAF test above will trip a MAF code CEL.
ECT usually does not give codes unless there is a wiring fault, so measure the resistance and compare to the chart.
PeteB
- Year and Model: 1996 Volvo 850 Wagon
- Has thanked: 57 times
- Been thanked: 11 times
Thanks everyone, I have an ohm meter and will do.
Forgot to mention that it idles hot very (100%) reliably at 1000 RPM, higher when cold,
never lower for the last year or so no matter the outside temp. Just to be clear cold
startup it is higher as would be expected.
Will a code reader that also reports temp, fuel trims, etc. give a much better idea of
the problem?
the problem?
It may, yes. It is great to have one that gives at least fuel trims, mine was stolen about a year ago and I really miss it. You might want to start a separate thread about code reader recommendations, or just hit the search button it gets asked frequently.
I had the Autel EU702. Really nice unit, also does SRS codes. You can still get it but I think it is a bit outdated - you can get more capable units now for about the same price. So while if somebody returned my old one to me I wouldn't bother to go shopping for another, I would do more research before buying right now.
PeteB
The IAC looks fine, kind of a sprung door in there, completely free to move.
Sprayed some carb cleaner in made little difference and it runs the same.
Removed the MAF connection, runs exactly the same and no CEL .... ?
Turned the ignition on for lamp test and it seems to be out!
So I need to read codes, probably a bad MAF, I'll search on what to do,
any specific suggestions for cleaning or whatever?
This thread seems to be good, 2nd post on - I will clean the connector:
viewtopic.php?f=9&t=53998
Seems I have to pull the cluster, again, and see what is up with the bulb.
You can test the MAF under operation using back probes at the connector, I have never tried it. Search this forum or the general internet for procedures. Doesn't sound like a MAF problem though, since it is the same unplugged. You did let it run for a few minutes unplugged? The ECU needs to go into default air:fuel mode (which is on the rich side), that can take a few minutes.
Since the bulb is out, it may have codes that can help greatly for diagnosis. I would reset the codes, run it, and then see what codes come back associated with the rough running.
other thoughts:
- Still a good idea to test the ECT when you can get to it.
- FYI cleaning the MAF connector sometimes helps, cleaning the MAF itself almost never does anything unless the sensor surface is visibly oily or dirty.
- What brand is the MAF in there, for the record?
- Does it chug at all engine speeds? Or at just a certain throttle position (wondering about the TPS)?
It absolutely sucks to throw parts at troubleshooting a problem like this, at the same time I always have a couple proven, spare ECT, MAF, CPS, TPS, crank, etc. sensors in a box in the garage. And fuel pump relays. It's so easy to make a couple swaps and then be certain about those parts of the system.
other thoughts:
- 173 Views
Last post by matthew1
- 12 Replies
- 2810 Views
Last post by greg850r
- 11 Replies
- 3255 Views
Last post by precopster
- 612 Views
Last post by GDavid
- 26 Replies
- 4106 Views
Last post by j-dawg
