my car 2000 s70 the clock stopped
can
Year and Model: 2000 s70 2.0 t5
Has thanked: 23 times
Post by can »
hi everyone ;
my car 2000 s70 Dashboard clock not working.I set up but like that staying.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Try to disconnect the battery and try a reset. Leave the battery terminals off for at least 10 minutes.
If you have a radio code you will need to have that handy.
can
Post by can »
clock 00:00 constant It is not progressing
the problem continues
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Fuse?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
can
Post by can »
I checked the fuse is solid
misha
Post by misha »
What happens when you try to adjust it?
Does the hour & min buttons responding?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
can
Post by can »
yes I'm trying to fix it. I set the time with the buttons but the time does not go , It stays constant.
Been thanked: 504 times
Post by cn90 »
Or try a new instrument cluster.
These days, used parts for the S70 are quite cheap on ebay, considering that these cars are now > 20 years old.
can
Post by can »
You are right, but maybe there is someone to help
Did you touch the removed battery lead to the other battery lead when you disconnected? This provides a total drain to the electrical system and may fix the problem. Other than that there really aren't any instrument cluster repairers out there given that you can buy a used one for around $50.
