My 98 v70awd has suffered an unfortunate HG failure. I'm debating what to do with it at this point. One option I'm looking at is a v70R 1998 and wondering if I can move my whole pile of performance parts from my v70awd in to it. This includes; ARD ECU tune, green injectors, TCV, RIP, snabb intake, and TD04-19tsc turbo.
Trying to look at better options than a head gasket. Plus I'm concerned it could be a cracked block and the HG wouldn't even fix it.
Thanks!
will my tuned ECU/turbo from my 98 v70awd swap in to a v70r?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Should. If the emissions system is different it may toss an emissions CEL. Probably should not have tuned an LPT engine anyways.
- Has thanked: 311 times
- Been thanked: 817 times
If the ARD tune is indeed for an LPT/2.4, then it will not likely be a straight swap into the 2.3 engine on a V70R. I would ask ARD. The ECU is the only tricky part, of course everything else will physically swap.
- Year and Model: Lots
- Been thanked: 128 times
The ECU wiring layout is the same. I would use the green injectors, TCV, RIP, snabb intake, and TD04-19tsc turbo and get a custom tune for the R.
Yes, physically the ECU is exactly the same inside and out, the only issue is the tune. ARD may well re-flash it more cheaply without charging for a full tune, since it already has one of their stickers on it.
That's about right. So much easier than a HG perhaps a full weekend of work.
ARD replied and said it will all swap right in but for best performance a retune would be good.
And to the grump who said I shouldn't have tuned the LPT...quit being a grump. ARD also noted the LPT is capable of more power than the R after tuning, so....yea
- 968 Views
Last post by RickHaleParker
- 27 Replies
- 2873 Views
Last post by kallekula
- 1025 Views
Last post by RigsPGT
- 2272 Views
- 14 Replies
- 3973 Views
Last post by Chuck W
