Cam/crank seal removal tool?
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
scot850 wrote:I have not had an opportunity to need to use it on the rear cam seals yet. So not sure how well it would work as it has a curved lip that needs to get under the seal. Sorry to not be able to answer this question for sure.
Neil
I see. You used Lisle tool on front cam seal ?
Thanks.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I really like that large kit for the puller tools. I was considering having a puller like that manufactured. Wasn't really sold on the installation tools because it doesn't look like the pushers don't have a lip to hold the lip of the spring open while pressing the seal in.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
mecheng wrote:what about a pick?
+1 That's what I use all day at work to remove seals, o-rings and gaskets.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
rspi
Post by rspi »
Here are the tools I had made for installing the seals.
Been thanked: 504 times
Post by cn90 »
I have now gone through some seals installations and can offer my advice for the Saturday mechanic.
1. The Front Cam Seal ---> Removal trick:
- Use a small punch and hammer, make a little dimple, then drill using the smallest drill bit, taking care NOT to mar the rotating surface on the cam shaft. The use a small sheet metal screw + Vise-Grips to get it out. You may need to drill 2 separate holes at let's say 3 and 9 o'clock positions.
2. The Front Cam Seal ---> Installation trick:
- Sometimes the lip "folds over" if you are not careful. So wet the seal with oil and during initial installation, spin it around the cam shaft until it hits the housing.
- The "secret tool" is basically a 1.5-inch PVC Coupler at Home Depot or hardware store. This is the coupler used to join 2 pieces of PCV pipes together, ask any plumber and he will tell you they use it daily for plumbing job.
- Cut the tool down so it is approx. 26 mm or so. Then deburr the inner and outer edges of the tool so it is clean.
- Now use the cam sprocket to drive the seal in, it is very very easy this way.
- Check with a mirror to be sure the lip is NOT folded over.
More info in my DIY Timing Belt thread:
https://www.matthewsvolvosite.com/forums ... =1&t=53722
Has thanked: 2199 times
Been thanked: 1851 times
Sorry a bit late replying, but yes, used the Lisle tool on front cam and crank seals only so far!
lcc014
Post by lcc014 »
Thank you for the clarification.
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
Got it. Makes perfect sense. Looks like a good tool.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
