The rearmost clamp for my exhaust has corroded and fallen off. The only reasonable replacement I can find is this but it has no part to attach to the hangar bracket.
Can I drill into somewhere to attach it?
How fit this exhaust clamp
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I don't think so. Plus problem with the rear hook besides rust is that the tail pipe after the muffler may crack and fall, can't support the whole muffler weight.
But there's good - if ghetto - news. I used a small chain from the hardware store, passed on a frame hole (remove rubber caps) above the muffler, then under the muffler.
qwertyjjj
- Year and Model: V70 2004
It's hanging with a metal coat hanger at the momentoragex wrote:I don't think so. Plus problem with the rear hook besides rust is that the tail pipe after the muffler may crack and fall, can't support the whole muffler weight.
Though that's not doing much than it isn't already supporting itself from the hanger further forward.
By "passed on a frame hole" do you mean you made a new hole in the underside frame?
Could I somehow get a steel hook and add it into this bracket and connect to the rubber hanger?
- oragex
I'll try take a picture tomorrow. That rear muffler bracket was poorly designed by V, happily as you found along many others, the whole muffler can stand by only the hanger after the front silencer. Mm something smells like Ford's hand here.
- oragex
Here,s how my chain is attached. It seems solid, it passes above by two frame rail holes - normally covered with a rubber cap. The muffler must be lowered to see these holes. Note that I don't have the muffler heat shield any more, which might be in the way.
Also the center hanger just before the elbow. Sells of Ebay but found mine on a scrap yard - quite easy to find one.
Notice how the tail pipe is completely broken where it enters the muffler. I'm about to weld it back in place but won't use it again to hang the muffler.
- c.jpg (99.71 KiB) Viewed 683 times
- b.jpg (120.34 KiB) Viewed 683 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It comes with a hanger. I installed two of them (on two cars).qwertyjjj wrote:The rearmost clamp for my exhaust has corroded and fallen off. The only reasonable replacement I can find is this but it has no part to attach to the hangar bracket.
- 752 Views
Last post by calvolvo
- 855 Views
Last post by a73s
- 11 Replies
- 1823 Views
- 709 Views
- 918 Views
Last post by polskamafia mjl
