Anyway anyone else got this annoying fault? My 99' V40 did the same thing but hitting the dash would fix it
850-Anyone have this OE radio problem?
- henrysin44
- Year and Model: 1994 Volvo 855 Turbo
- Has thanked: 2 times
- Been thanked: 3 times
For the past few weeks the reception on my radio frequently decides to be terrible! Normally the reception is excellent allowing me to pick up stations from NY and MA (live in CT) although now most stations have a layer of static that goes away after awhile then comes back. I have noticed it gets to static when I hit a pothole but has happened too infrequently to be the cause. I'm gonna look into the antenna connections in the hatch and swap the booster. All else fails gonna pull a antenna mast and switch off a 850/v70 sedan and bolt it on the fender
might even look cool
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
- Has thanked: 1613 times
- Been thanked: 4078 times
Pop the stereo out and check the antenna wire hasn't walked out? It's Just a friction fit.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Or oxidized. Plug and unplug a few times to wipe the contacts.abscate wrote:Pop the stereo out and check the antenna wire hasn't walked out? It's Just a friction fit.
DeathRex
- Year and Model: 1996 850 Turbo
I have it too. I found it is in the radio, resoldered the antenna didn't fix it. On mine it's in the PLL tuning section. Sometimes when you change channels, using the push buttons, and go above 94MHz all I get is static. Then if I change channels, using the push buttons, down to 1 or 2 and work up to 6 the radio works, but from 1 straight to 6 gets me static. The lower buttons always work, but tapping on the circuit board with a plastic screwdriver still makes a static noise. I resoldered about 100 joints on the PCB, it got better, but didn't fix it. Either I need to resolder all of them or its got a mechanical filter going bad.
Number 2 son, who uses the car only listens to MP3s, but I replaced that antenna and I'd like to get the radio working all the time.
- Has thanked: 2215 times
- Been thanked: 1853 times
When PnP up here has a sale, the Volvo radios with single CD sell for about $10-15 CDN. Not worth fixing unless issue is obvious or you like a challenge.
- 1047 Views
Last post by rice240
- 1680 Views
Last post by hightech24
- 14 Replies
- 2689 Views
Last post by bugs11
- 168 Views
Last post by matthew1
- 1433 Views
Last post by vjaneczko
