Tick long pause tick ___ under glove box
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
ok quite right turned off and no tick, how do I replace the lever? can I get one from the JY you think? Thanks
loveMy850
Post by loveMy850 »
On that arm,can I get a replacement at the JY, I read somewhere these were a B to replace,or is it easier to leave broken arm on and try and repair it,Thanks
Has thanked: 2199 times
Been thanked: 1851 times
When I went looking for one in PnP last year for my 97 850 project, the air intake flap arm was probably broken 50% of the time. They can still be bought new from the dealer. Part # 6808653.
loveMy850
Post by loveMy850 »
HAPPY NEW YEAR everyone. Can I pull a arm lever from the JY,and is this an easy project, or is it easier to try and refuse the one thats on there somehow, whats the best way to fix this?
loveMy850
Post by loveMy850 »
Just missed your reply Neil Thanks,
loveMy850
Post by loveMy850 »
whatcha talkin about Sailor?
Sorry missed your thread. Yes it is fairly easy to replace. The 850 is a little more tricky than the V/S70 only due to access to the 2 screws you need to remove from the glove box hatch. You may be able to do it just by removing the lower dash cover (2 or 3 screws). I think you may be able to replace it without removing the glove box, but visibility and access may be tricky.
actuator arm (1)
actuator arm (1)
actuator arm (2)
actuator arm (2)
You can see one end is missing part of the square drive hole for the servo motor.
Yes you can us a JY one if you can find one. It depends on how much time you have to find a good one and then how old is it? Check with the dealer on the price, it may be low enough not to bother going to the JY unless you are going for something else.
Neil
