Glad it was that easy! It is great when an issue turns out to be a relatively cheap and easy fix.
Well done that man!
1999 V70 T5 Incident Report MAF Turbo (FIx: Induction Leak) Topic is solved
- Has thanked: 2199 times
Notes on repair. I did swap in the new MAF before I caught the boost pipe fitment problem. Tugging off the MAF I pulled off the air cleaner induction pipe off the turbo way too easily, and sure enough I did not have a good fitment on that connection.
Put the PCV purge hose on first before connecting to the turbo...on the 1999 there is a lot of tension on the PCV hose. Make sure the PCV clamp grabs the hose and not the plastic ridge on the induction hose
I used SS clamps ( worm drive) and got them nice and tight. They do boost up to pressure, of course
I put the old MAF back in and now have a known to be good spare Bosch MAF
For posterior - here were the reported codes from the induction hose leak - neither code had anything to do with failure.
Also added picture of plastic boss/PTC nipple detail above.
Last bumped by abscate on 23 Mar 2020, 08:51.
- 23 Replies
- 6425 Views
- 1738 Views
- 1343 Views
Last post by wizechatmgr
- 1436 Views
- 2107 Views
Last post by MadeInJapan
