Documented here
Top one is 1999 P80
Bastard 1999-2004 uses part 9125463
Bottom one 2005 p2
Engine coolant temperature resistance chart P80 9186486 and P2 9125463
- Has thanked: 1500 times
- Been thanked: 3810 times
I am a bit worried the 1999 ECT is different than the earlier P80s, so if someone comes up with the chart for -1998, lets put it here too.
For search purposes, you have to use the whole name for ECT, as three character strings are ignored in Search.
- Been thanked: 466 times
I measured the Ohm readings on a brand-new Volvo ECT for 1998 S70 a few years ago in my kitchen/freezer etc.
The readings were (these were actual measurements):
* -20C: 16,000 Ohms (16 kOhms)
* 0C: 7,300 Ohms
* 20C: 2,600 Ohms
* 80C: 300 Ohms
* 90C (Operating Temp): 200 Ohms
* 100C: 150 Ohms
PS: According to Volvo, PN 9186486 fits:
Volvo 850 1993, 1994, 1995, 1996, 1997
Volvo 940 2.3l Fuel Injected 1991, 1992, 1993, 1994, 1995
Volvo 940 2.3l Fuel Injected Turbo 1991, 1992, 1993, 1994, 1995
Volvo 940 SE 2.3l Fuel Injected Turbo 1991, 1992
Volvo 960 2.3l Fuel Injected Turbo 1992
Volvo 960 3.0l 6 cylinder Fuel Injected 1992, 1993, 1994, 1995, 1996, 1997
Volvo C70 2.3l 5 cylinder Turbo Convertible 1998, 1999, 2000, 2001, 2002, 2003, 2004
Volvo C70 2.3l 5 cylinder Turbo Coupe 1998, 1999, 2000, 2001, 2002
Volvo C70 2.4l 5 cylinder Convertible 2000
Volvo C70 2.4l 5 cylinder Turbo Convertible 2000, 2001, 2002, 2003, 2004
Volvo C70 2.4l 5 cylinder Turbo Coupe 2000, 2001
Volvo C70 2.5l 5 cylinder Turbo Convertible 1998, 1999
Volvo C70 2.5l 5 cylinder Turbo Coupe 1998, 1999
Volvo S70 2.3l 5 cylinder Turbo 1998, 1999, 2000
Volvo S70 2.4l 5 cylinder 2000
Volvo S70 2.4l 5 cylinder Turbo 2000
Volvo S70 2.5l 5 cylinder 1999
Volvo S70 2.5l 5 cylinder Fuel Injected 1998
Volvo S70 2.5l 5 cylinder Turbo 1998, 1999
Volvo S90 3.0l 6 cylinder Fuel Injected 1997, 1998
Volvo V70 2.3l 5 cylinder Turbo 1998, 1999, 2000
Volvo V70 2.4l 5 cylinder 2000
Volvo V70 2.4l 5 cylinder Turbo 2000
Volvo V70 2.4l 5 cylinder Turbo XC 2000
Volvo V70 2.5l 5 cylinder 1999
Volvo V70 2.5l 5 cylinder Fuel Injected 1998
Volvo V70 2.5l 5 cylinder Turbo 1998, 1999
Volvo V70 2.5l 5 cylinder Turbo XC 1998, 1999
Volvo V90 3.0l 6 cylinder Fuel Injected 1997, 1998
* 0C: 7,300 Ohms
* 20C: 2,600 Ohms
* 80C: 300 Ohms
* 100C: 150 Ohms
It looks like the tolerance ranges from 50-100% on the high side!
