Hi all, before I start messing about under the hood I'd like to get feedback and ideas from the group.
I have a US spec 2000 V70 - it has the base 2.4 n/a engine, FWD, 5 speed auto, 170,000 miles.
Outdoor temp has been in the teens (F) lately, and when I drive the temp needle barely moves and the level of heat barely comes out. If I stop and idle for a while the temp needle raises, but never to optimal, and 'hotter' heat comes out. The fan and vent controls work fine. No smell of anti-freeze. No visible leaking of anti-freeze outside. I don't know when the last time the anti-freeze was changed/flushed. I top off the reservoir once or twice a year as needed.
When the outdoor temp is above freezing the car heat is fine. Car never overheats.
I have my suspicions but I'd like to hear your thoughts or experience.
Thanks!
Help diagnose low heat
2015.5 V60 T5 AWD Platinum
2012 XC60 T6
2012 S60 T6
2011 S40 T5
Gone but not forgotten:
2009 C30 R Design Sold to buy more Volvos
2007 S40 2.4 t-boned and totaled
2010 V50 2.4 hit a deer and totaled
2000 V70 SE head gasket
2000 S70 SE sold with 240,000
2012 XC60 T6
2012 S60 T6
2011 S40 T5
- Has thanked: 1611 times
- Been thanked: 4075 times
Either thermostat is kaput or your cooling system is plugged up. Coolant should be refreshed about every 2 years for most drivers per the manual.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Your thermostat is broken in the open position. This is a quick 5 minute fix. Just be careful removing & installing the Torx screws as not to strip them. I would get a quality replacement from a site like FCP Euro or iPdUSA.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 2210 times
+1 on the stuck thermostat.
Also check the cold air flap doesn't have a broken lever arm. That requires removing the glove box and lower panel on passenger side to see. You might be able to see with just removing the glove box liner. The cold air lever arm is right behind there and is either white or black and about 2-3" long. This will not affect the low needle on the temp. gauge, but does reduce how much hot air gets into the cabin. Also make sure the cold air flap is closed by turning the rotary control to the left of the center dashboard vents to the closed position.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Whatever you do, do NOT beat on the screws, I have no idea why people do that and destroy the thermostat housing. Not fun to replace.
I replaced the stat with Volvo 271664, with seal. Cost me $30.38 out the door from the dealer. This stat does not have the weep hole that the installed one has (I assume it is the original). The heat is working fine but the ambient temp yesterday was in the 50s, today it may hit 60 so I'll have to wait for a colder day to test it for sure. Thanks
2012 XC60 T6
2012 S60 T6
2011 S40 T5
2012 XC60 T6
2012 S60 T6
2011 S40 T5
- 954 Views
- 17 Replies
- 4480 Views
Last post by coldax
- 2796 Views
Last post by Legofan
- 16 Replies
- 6851 Views
Last post by Aintezbeincheesy
- 1195 Views
Last post by maraschino
