Engine code
Cincyken
Year and Model: 1995 850 T5-R
Post by Cincyken »
My 1995 T5-R check engine light came on so i had it read at Advanced Auto, they said it was "bank 1 rich". I cannot figure out what that means.
Also, for some reason my service light on the dashboard came on and is flashing. It comes on when it is due for service, but has never flashed before. What does that mean?
Has thanked: 1611 times
Been thanked: 4075 times
You should always get the 'P code' not the description. since the descriptions are often wrong.
You want the data in format P1234, P followed by four numbers.
If this is right, its usually means you are getting excess fuel somehow - perhaps a faulty Fuel pressure regulator, but there are many causes to explore.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Bank 1 rich can be anything(from vacuum leak to o2 sensor).You must demand particular code in P format or Volvo code from Advanced Auto...OR...since it's '95,you have diagnostic ports under the hood.Read the codes yourself and post 'em here.
About service light flashing....i think that your instrument cluster is going bad....and you can also read the codes yourself.
http://volvospeed.com/volvo_repairs_how ... es_a2.html
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Cincyken
Post by Cincyken »
I appreciate the info. I followed the written procedure and got one code.
2-3-2- Long term fuel trim at limits at idle.
Ok, but now that i know that, where do i start?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
So you're running rich... check for vacuum leaks at the easy-to-see hoses. Check the TCV hoses and purge valve hoses for cracking or obvious tears. Also check out the corrugated part of the intake hose to the turbo... it's possible that it is torn.
Cincyken
Post by Cincyken »
Would not a vacuum leak result in too lean a mixture. Why would a vacuum leak result in a rich mixture? I have never seen a 2-3-2 code before on any Volvo i have owned over the years.
misha
Post by misha »
Ecu enriches the mixture to compensate.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Does the 1995R use the vacuum operated fuel pressure regulator? Thats a common failure point to check.
misha
Post by misha »
Yes it does.It's vacuum line could be the suspect.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Cincyken wrote:I have never seen a 2-3-2 code before on any Volvo i have owned over the years.
Unless you have had very bad luck there are dozens of codes you've never seen pop up on any of your Volvos.
