Low signal to temp gauge
mouseskowitz
Year and Model: '02 and '04 V70
Post by mouseskowitz »
So the check engine light is on in my '04 V70 2.4. The computer is telling me that the temp gauge is getting a low signal. Sometimes the needle takes forever to get to the normal mid line and other times it never makes it. Can I be confident that I just need to replace the temp sensor or are there other common problems?
2002 V70 2.4T ~202k miles
2004 V70 2.4 ~92k miles
Been thanked: 4068 times
search the P80 (the one above) forum for
'engine coolant temperature resistance chart'
and you will find the thread to test the sensor.
I would put your odds at a bad sensor at 90%
mouseskowitz
Thanks! So, basically if it's significantly off from those readings the sensor is bad.
mouseskowitz
@abscate I'm getting 2160 @19.6°C. I'm thinking that's far enough off to call it bad. What do you think? I'll check again in the morning when it should be ~0°C.
mouseskowitz
The engine was 0.9°C this morning and it was reading 5160. So the part is ordered. Should be able to put it in next weekend.
