I need to replace the Alternator. It's 1998 S70 T5, so being a turbo, that means I've got even more lines and tubes in the way making this job extremely difficult. I've got every single bolt out that I need to but I absolutely cannot find the final bolt (longest?) that is suppose to be behind the alternator which I believe screws through a bracket holding the alternator. I watched the YouTube video (many times) by RobertDIY for replacing the alternator. He says at 8:14 that there is a "lower alternator bolt" and it's a "12mm"
Please help. I cannot see a 12mm bolt and I just purchased a longer ratchet wrench to help out and I still cannot find the bolt.
1998 S70 T5 - Can't find last bolt to remove PS bracket and Alternator
SleeStak69
- Year and Model: 1998 S70 T5 5MT
Reason: Please no "Help" in titles. Read the rules. Thanks.
Pewter Silver Metalic 1998 S70 T5 5 Speed
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I recently posted a few videos of me tearing down an 850 sedan (Ghost). I'm pretty sure one of those videos shows all of the PS bracket & alternator bolts location.
As the video explains, it helps to raise the PS bracket assembly up and out of the way. If that lower bracket bolt is what you are referring to, the bolt screws into the bottom of the bracket. On the passenger side of the bracket you should be able to see the square shape that the bolt treads screw into.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, assuming it's same as P2. The a/c compressor lower bolts (below the compressor) must be slacked a little, for the compressor/alternator bracket to be loose enough to slide the alternator upwards. On my 2003 the two bolts in question were quite seized.
SleeStak69
Got it done. I ended up having to remove the transmission coolant line and a power steering line to reach that damn bolt. All I have to do now is put the serpentine belt back on and fill up the coolant and Power steering. What a pain in the ass though.
- Been thanked: 4068 times
Yeah, the alternators on these cars are buried well. It's a low maintenance part, to be fair, though.
1/4 inch ratchets and lots of wobbles are helpful
- rspi
Contact rspi..
Do you mean the oil cooler line? Transmission cooler lines are on the left/driver's side of the radiator.SleeStak69 wrote:Got it done. I ended up having to remove the transmission coolant line and a power steering line to reach that damn bolt. All I have to do now is put the serpentine belt back on and fill up the coolant and Power steering. What a pain in the ass though.
SleeStak69
Yes. The oil cooler linerspi wrote:Do you mean the oil cooler line? Transmission cooler lines are on the left/driver's side of the radiator.SleeStak69 wrote:Got it done. I ended up having to remove the transmission coolant line and a power steering line to reach that damn bolt. All I have to do now is put the serpentine belt back on and fill up the coolant and Power steering. What a pain in the ass though.
- 10 Replies
- 3020 Views
Last post by hausmeister
- 11 Replies
- 3229 Views
Last post by youngin9494
- 10 Replies
- 6396 Views
Last post by volvolugnut
- 12 Replies
- 3760 Views
Last post by JimBee
- 1530 Views
