Cost to replace V70 engine
Volvodummy
Year and Model: 2005 V70
Post by Volvodummy »
2005 v70 dignosed as bad motor, no oil pressure. 300k. I was given price of $3300 total to put a 76k engine in. Still shopping around. I'm in Florida. If anyone could advise on place to get engine? I want to try and get her fixed up. Especially if I can drive a few more years. I could just put the money toward another car, but the body is great and I love the safety and comfort of this car. What other Volvo models and years have the same engone? Should I stick to the same year and model for engine? It is a 2.4 non turbo v70. What is a normal range price for the labor on engine replacement? Thanks for your help!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
A bit high but not ultra out of line
2005-2007 have the same engine
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
The engine is B5244S, it was installed in a bunch of models through the whole P2 platform life span: https://en.wikipedia.org/wiki/Volvo_Mod ... ine#B5244S
The most bulletproof 5-cylinder engine Volvo ever made, but it still requires a regular and quality oil changes.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
The 6th and 7th digits of your VIN number indicate the engine code. For instance, my 2003 V70 NA is 61:
61 = B5244S S60/V70 2.4 FWD
I'm not sure if your 2005 carries exactly the same engine code or not. Hopefully there are a lot of S60's out there with the same engine as yours which would open up the market quite a bit for you to go shopping.
Been thanked: 4067 times
3 years for $3000 is much cheaper than anything new, and beats a lot of used cars!
The price is about right but there are always uncertainties with a used engine that you can't really 'insure' against
I have that same engine in my 2005 and it is a dreamy, quiet, powerful piece of work that gives me 32 mph highway...insane..
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I would just keep all sensors and accessories for spare or just in case the computer won't like the sensors coming with the replacement engine.
I feel $3300 is on the steep side, the garage is making good money here but most Volvo specialists are like such. The labor should be under $1000 (not at the main dealer) and the engine under $1000 as well. Given the car mileage, I'd rather try to find an engine off Ebay for under $1000, may also look at some scrapyards near your location on local.google.com. With a replacement engine, I would remove the oil pan and check the PCV system before installing, wouldn't be surprised what killed your engine was a clogged PCV. Keep your transmission if it works well.
I'd keep in mind that at 300k a Volvo starts breaking parts so expenses may go up in the next 100k miles or so so the rest of the car might not go much past 400k.
vtl
Post by vtl »
Replace all seals as well, crank/cam, and in the pan too.
$1000 for an engine swap? pulling one, replacing another, as well as dealing with engine and shipping - that would be pretty light for a shop rate
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
I have recently been quoted $900 labor
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
It’s an old thread but $900 labor to pull and install an engine is way under actuals.
Remember in Canada, labor rates are much cheaper than the US ( quote upthread from 🇨🇦
