Bad news.Your options are to rebuild the head or get used one.You will need also a set of gaskets and reputable timing belt kit with water pump.
That will be costly even if you do repair yourself.Maybe it's time for a newer or other Volvo.
Seized water pump after only 45k...it must be a total junk and "no name" brand.
'96 Platinum Wagon: broken timing belt. 7:18am Topic is solved
Failed Water Pump Causes Timing Belt Failure
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Fortunately, OP lives in an area with a large Volvo population, another motor may be the quick and cost-effective solution. Your Platinum is an LPT car, right? so a 96-98 LPT motor isn't a 350 chevy, but they are out there. If you have a Platinum in good shape, a motor swap might make economic sense. Best of luck however it goes for you.
oops-edit. So I see they were HPT, so any turbo, T-5, or R from 95-08 should be a candidate I believe.
Current Volvos:
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I have seen aftermarket water pumps fail in less than 20,000 miles. So sad.
- Has thanked: 316 times
- Been thanked: 531 times
You better get on finding the brand of that water pump... I think everyone wants to know if it failed at just 45k miles. I hope it isn't a Hepu.
All this timing belt talk the past few days is really making me want to replace mine soon, even though it looks good. I don't trust the PO's mechanic to use good parts.
splats
- Year and Model: 1996 850 Turbo Wagon
I have the water pump out. It looks like the bushing blew up and allowed the shaft to tip a bit. The blades gouged into the pump housing, got wedged, and sheared some teeth off of the timing belt. If I shake the water pump, it rattles - pieces of the bushing are still in the housing.
I'm of the mind that the bushing/bearing was packed with grease, and that grease ended up in my coolant. It also flung out all around the inside of my timing belt cover.
I'm unable to locate the invoice, so I don't know who makes it - it was 4 years ago and we've moved since then. The water pump doesn't have any identifying brand on it. On the housing, it says '1D6P', and on the end of the shaft it says "12 12 4 WR".
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Bummer...we feel your pain. It is indeed heart-wrenching to hear this happen to another old car.I'm of the mind that the bushing/bearing was packed with grease, and that grease ended up in my coolant. It also flung out all around the inside of my timing belt cover.
Beware that either TB tensioner or idler pulley can wear, allowing the TB to slide off. I caught mine before this happened thank God. You can search through my back posts for the photos. It was an INA bearing too. OEM. It was Tango Uniform before 70,000mi.
Might be a good idea to do at least a yearly inspection by removing the TB cover and having a look with a bright light.
M1 10W-30 HM
M1 10W-30 HM
- misha
....Hepu or SKF.cn90 wrote:Whatever you do, get Aisin!
About $55 online...
SKF is better.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 5320 Views
Last post by jimmy57
- 23 Replies
- 17310 Views
Last post by jonesg
- 20 Replies
- 17517 Views
Last post by Hurtfeelings
- 40 Replies
- 7993 Views
Last post by matt122s
- 10 Replies
- 3970 Views
Last post by rspi
