Is there a break in period after a valve job?
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Just had 3 valves, one burnt through, replaced in my 850t runs great. Entire head was machined properly, etc. New seals. Question is should I drive especially carefully (basically I do anyway), change the oil and filter in a few miles, what if anything should I be mindful of.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
After I replace a head I run cheap oil for 50 miles, change it with cheap oil, run another 100 miles. Then change it and the filter with my good oil. No real break in period.
- Been thanked: 4067 times
Neil will sell you his oil from his last oil change. Drive a hard bargain, though.
rguzz
Okay! I figured I'd change the oil you guys are suggesting sooner rather than later. I asked them to put dino oil in after the valve job which is what is in there so I'll replace x 1 then put my high mileage Mobil One 10w-40 in and monitor oil consumption!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No breaking in period required after a valve job.
Regular oil change interval like nothing happened.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
I do like what rspi says. One or two quick changes of cheap oil.
rguzz
It's interesting the re-builder didn't have anything to suggest and shrugged when I started to come up with a post rebuild frequent oil change scheme. I'll most likely change what they put in after a few more miles, replace with my usual synthetic oil x 1 and call it quits.
- Year and Model: Many Volvos
- Been thanked: 76 times
Back when I was building race boat engines (outboards that ran on alcohol / castor oil) the ruling philosophy was that if you break them in hard they run hard. We would light them up with the assembly lube and pretty much immediately run them up to 10,000 RPM. That usually worked out fine but there were a few notable exceptions.
