Hi!
Just finishing up a valve job on this 1999 V70 Turbo AWD I got this summer. Cyl 2 had bad exhaust valves and previous owner said that his mechanic disabled #2 so it wouldn't dump raw fuel into the cylinder and ruin the cat.
So... assuming there is nothing broken, where would I look to see where it could have been disabled? Where is the most convenient place to do that outside of disconnecting the cable at the injector?
Thanks!
Jeff
P0202 - Mechanic disabled Cyl 2?
adkvolvonoob
- Year and Model: 1999 v70
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Just the connector at that injector.
'99 should have coil packs over the spark plugs.Check if he disconnected it for some reason....and that's it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
adkvolvonoob
Thanks for the input guys. I'll be doing some troubleshooting of the fuel rail today as well as moving coil packs around.
When I tore into it to get the had sent out (bad exhaust valves, same cyl...makes sense if the mechanic disabled fuel to that cyl) I saw that the connector on that injector was still connected. It's where I would have disabled it. Will also look into testing voltage at that connector and maybe sticking an LED in the connector, as well as testing the spray patterns of all the injectors.
adkvolvonoob
Did some troubleshooting...
All injectors are firing. I cleared the codes and that hasn't shown up yet
Moved to the coil packs - found Cyl 1&2 are not firing. cleaned common ground point, swapped packs to working cyl - doesn't seem to be a problem with them, swapped spark plugs, failure stays at 1&2. Now looking to see if I can get any info from the connectors at those coils, test grounds, etc.
- Has thanked: 316 times
- Been thanked: 531 times
Have you tried switching the connectors on the first and second coils? They look like they'd be hard to mix up, but it's a lot easier than you would think. Ask me how I know...
The colour coding for the coil pack cars is in the VRD and also in my 1999 maintenance log, too
couple of links
viewtopic.php?f=1&t=63110&p=325109&hili ... il#p325109
couple of links
That's right, I remember you mentioning that on my thread. The diagrams are out there!
- 1649 Views
Last post by RickHaleParker
- 434 Views
Last post by scwd1
- 1712 Views
Last post by petermetzger
- 1737 Views
Last post by Livens
- 1239 Views
Last post by fredbyte
