Thermostat replacement without the housing
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Could be- we had figured out a Gates fits it...forget the part number. I would be tempted to switch out the temp sensor on the housing at the same time. I deduce that's the main reason Volvo sold the whole thing anyway (many complaints only after the thermostat replacement).
oragex
Post by oragex »
The Gates TH35991 I think
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
MadeInJapan wrote:Could be- we had figured out a Gates fits it...forget the part number. I would be tempted to switch out the temp sensor on the housing at the same time. I deduce that's the main reason Volvo sold the whole thing anyway (many complaints only after the thermostat replacement).
Housing cover does not have a gasket. If not mating surfaces not super clean, or the cover not tightened enough, or t-stat itself installed in a wrong direction, or it's bent slightly (and it does easily) than it's starting to leak.
F250
Year and Model: 2007 S60 2.5T
Post by F250 »
The eBay part shows as "not compatible" with my daughter's '07 S60. I can only assume that this is NOT a new thing, but is simply another stat which is compatible with the old style housings.
______________________________
Pete - '07 S60 2.5T, Gray FWD (Daughter's car)
My Garage includes '02 F250 7.3L Diesel w/285K, '03 Excursion 7.3L Diesel w/196K, '06 Outback Limited 2.5L w/228K, '99 4Runner 3.4L 2WD w/220K
