Ok folks, I'm 200 miles from home and the CE lit up. Forgot the code the guy at napa gave me but he said O2 sensor is slow to respond. Can I drive this home 200 miles or do I have to fix this today?
Gordon
Help on O2 sensor
Jaguar xjs
- Year and Model: 1996 850 turbo
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Is it front or rear o2?
If it's the front and not showing symptoms of running rich(black smoke from the exhaust),drive it and forget about o2 sensor.
If it obviously running rich then reset the code and drive it home.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Drive it home. You will probably need a new front O2 sensor, check around for a good price. The CE light is almost always due to emissions fault, just have to get it fixed before inspection.
Klaus
Jaguar xjs
Car started running really bad and black smoke. Had the front O2 sensor changed with a Bosch part. I hate paying people to do things I can do but sometimes you just have to. Thanks for the help!
Gordon
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
- Has thanked: 1614 times
- Been thanked: 4078 times
You usually can get home by unplugging the MAF sensor in this case.
Glad you got it straight
Jaguar xjs
Well this is disappointing. 50 miles from home the CE lights up. Pull into Advance and they pull the same code as yesterday. Front O2 sensor slow to respond. Going to try and figure out getting a warranty repair near my home. Now I'm not so sure a Bosch piece was fitted and they subbed an aftermarket but it seems to me even an aftermarket should last more than 150 miles. Not a happy camper today.
Gordon
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
- misha
That's what i was afraid of.
What was the actual code?
It could be that you have a vacuum leak somewhere or an exhaust leak(like flexi pipe).
The other thing can be that they spliced the connector on new o2 sensor which these cars don't like at all.Only oem Bosch with direct fit connector.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Jaguar xjs
Thanks for the reply Misha. Code pulled was P0133. Doing some reading I'm thinking a vacuum or exhaust leak. It appears the new front O2 sensor is a direct fit with no splicing. Will put the smoker on the intake side but I do think it it is an exhaust leak since the car has that exhaust leak sound. The previous owner did say he had a couple holes filled so I'm thinking there may be some random holes that need to be attended to.
Gordon
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
- misha
Exhaust leak will ONLY affect front o2 sensor reading if it's between exhaust manifold and cat.
If the leak is between a cat and rear o2 it would affect rear o2 sensor reading.
Everything after rear o2 doesn't matter neither for front,neither for rear o2 sensor reading.
Flexi pipe is the weakest connection in there.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
