how much power do i want this car to make?
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
If you want to get to 300 HP, the easiest way is an IPD tune and an IPD exhaust system. That will cost you about a little over $1,000 if you buy everything on sale and can easily be done at home. Obviously, before you make these upgrades do a stage 0.
biohazrd76
- Year and Model: 1997 850R
Its been a while, but so far the engine has:
Stage 0
Ipd stage 1
Msd coil
Hd tcv ipd
15lb Cbv spring upgrade/diaphragm swap ipd
Snaab intake tube + k&n cone filter
Homemade airbox
NA intake manifold and TB swap with port and polish
Ipd intake spacer
Ipd RIP kit
Obx downpipe
No dyno information yet
Stage 0
Ipd stage 1
Msd coil
Hd tcv ipd
Homemade airbox
Ipd intake spacer
Ipd RIP kit
Obx downpipe
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
- Has thanked: 316 times
- Been thanked: 531 times
When you say OBX downpipe... did you put in just the downpipe or the whole exhaust? I'd like to get just the DP for my car, but I don't know how to go about putting it in and keeping the cat.biohazrd76 wrote:Its been a while, but so far the engine has:
Stage 0
Ipd stage 1
Msd coil
Hd tcv ipd
Homemade airbox![]()
Ipd intake spacer
Ipd RIP kit
Obx downpipe
biohazrd76
Just the downpipe I found for sale on eBay for my Straight flange Turbo for $150 I am in the process of welding V band connections into my already custom exhaust looking into high flow cat options but I am being told I can use OEM cat
1997 850 R, black.
biohazrd76
Siliconeintakes.com has lots of cheap goodies for this job
1997 850 R, black.
Cool, I'll have to do that. My cousin is getting the OBX system and giving me the straight flange DP for some other parts I gave him, and I don't want the whole system. I want to keep it a little subtle.
I think he wants a high flow cat, but I think I want to try to use a stock cat.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
It's worth considering a high-flow unit. They're not that expensive and you can get whatever size you want, so you don't have to step the diameter down and back up in the middle of a big downpipe. You can also get them in stainless, which is nice.
That's a good point. Less restriction is what the goal is anyway.j-dawg wrote:It's worth considering a high-flow unit. They're not that expensive and you can get whatever size you want, so you don't have to step the diameter down and back up in the middle of a big downpipe. You can also get them in stainless, which is nice.
biohazrd76
I agree, im hearing mixed info on the longevity of the universal high flow units. And to copy ipd system, i need to move the 02 bung downstream a few inches to account for hotter exhaust temps, says the ipd video. I think im going to run the oem unit and see what its like, maybe stay at 2 1/2 from cat back. A FULL 3" system isnt really necessary im reading that DP is the most crucial item to be larger. And they talk more about the shape being a "gentle bend" instead of the stock ? Shape
1997 850 R, black.
From what I've heard from people who have installed the downpipe before the rest of the exhaust, the DP makes the most difference as far as performance goes. Which, judging by the stock unit, the OBX should help open things up quite nicely. Similar to the stock intake tube compared to the Snabb intake. I just installed a Snabb intake in my cousin's S70 the other day and if you compare the Snabb to the stock corrugated plastic tube, the difference is incredible. You can't tell me that the new intake doesn't do anything. Between the smaller diameter and the bottleneck by the PTC, you're probably gaining a lot of airflow.
- 18 Replies
- 10976 Views
Last post by erikv11
- 354 Views
Last post by hausmeister
- 1735 Views
Last post by Freestate
- 10 Replies
- 1651 Views
Last post by MrAl
- 905 Views
Last post by Stoffelmans
