Bad coolant leak
Jaguar xjs
Year and Model: 1996 850 turbo
Post by Jaguar xjs »
I just replaced all the coolant hoses and completely agree with erickv11. That lower turbo hose can be a bear to remove and since you pretty much have to strip the left side of the engine to get access, if it's in the budget I'd replace the heater hoses also. Classic case of WIIT. WHile I'm in there!
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
Has thanked: 1613 times
Been thanked: 4078 times
Ive got a spare turbo outlet hose, Volvo OEM
Been thanked: 504 times
Post by cn90 »
I posted the PNs for the Turbo coolant hoses and the tips/tricks in the thread below.
Do NOT buy URO or aftermarket hoses!!!
Stick to Volvo OEM hoses, which are not expensive at all.
DIY: 1998 S70 GLT Turbo Coolant Hoses and 2 Radiator Hoses
viewtopic.php?t=55306
Has thanked: 312 times
Been thanked: 818 times
Heater hoses I would inspect and probably only replace if they seem to be aging poorly. Those factory hoses are superbly well made, they fail rarely so if they look good they probably still are. I'm not sure the newer heater hoses from Volvo are the same high quality (abscate may have some comments about that point).
But whatever you do, do not buy aftermarket heater hoses, unless you decide to do one of the ghetto swap methods (uses regular heater hose, not the pre-formed ones with the metal nipples).
