Longevity of HEPU pump?
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I've started putting the engine back together after replacing the valve stem seals and I figured that, at ~60k miles, I might as well replace the timing belt while I have it off. Poking around, I noticed that the water pump is a HEPU unit.
Since I've just pushed the timing belt change off by 100k, this HEPU pump will presumably have 160k on it when I change the belt next (assuming the car is still with me at 365k, which is maybe a bit of a question mark). Would a HEPU pump be expected to make it this far? I actually have already bought an Aisin pump, but it wasn't cheap and I'd just as soon not mess with the water pump if it's fine as-is. Sleeping dogs and all that. I see no leaks and feel no play in the bearing.
The tensioner and idler are smooth and quiet, so I'm not planning to replace those. It sounds like water pump failure is the more common belt-snapper.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I would leave it alone if it doesn't leak and bearing is good.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
10 Years, 140,000. I have heard of some failing at 35,000, but they usually leak first.
beigg
Year and Model: 850 97
Post by beigg »
I'd change it.
ugh smh 850 Turbo fridge
beigg
Post by beigg »
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
They were better then than they are now.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
If it were me I'd replace all of it. You're already in there - the last thing you want to do is have to be in there again...
Has thanked: 311 times
Been thanked: 817 times
Plus at 264k, if you don't install the Aisin pump now you may never get to it. In your shoes I would replace it, even though the water pump job is one of my least favorite when the engine is already installed. Remove the serp tensioner, it is super easy to do and opens up a lot more room for getting your hands in to the work space for the portions where you are working from above.
j-dawg
Post by j-dawg »
UGH FINE YOU GUYS I'LL DO IT
beigg
Post by beigg »
glad we could all shame you in the right direction!
