P80 lower timing belt cover bolts 974674
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
skloon wrote:They look like the lower timing belt shield bolts
This.
johnhb
Year and Model: 1997 V70
Post by johnhb »
beigg wrote:Is your caliper still hanging off the bracket?
No, I did not remove the brake caliper. Plenty of room to get to the crankshaft pulley without doing that.
beigg
Year and Model: 850 97
Post by beigg »
This.
bingo x2
ugh smh 850 Turbo fridge
Been thanked: 504 times
Post by cn90 »
Yeah,
LOWER Timing Belt guard bolts...
johnhb
Post by johnhb »
beigg wrote:
MrPc wrote:Those bolts look vaguely familiar..... By any chance, do you still need to install the belt guard that goes around the bottom of the crankshaft pulley? It seems to me that those bolts are similar. IIRC the long nose helps get things lined up and the threads started. (Although I still found it a kinda hard...)
Bingo!
Ok, if these special bolts hold the timing belt guard around the bottom of the crankcase pulley then I have two standard M7 bolts left over. That may be a better option. Thanks for inputs.
johnhb
Post by johnhb »
many thanks to all who contributed. They do belong to the timing belt lower cover. I've obviously fitted the cover with standard M7 bolts.
:D
Has thanked: 312 times
Been thanked: 818 times
The now-extra M7 bolts may be for the upper, outer plastic timing belt cover, where it screws into the cam cover.
beigg
Post by beigg »
glad you didnt start it up. High probability for interference issues.
Such interference could cause catastrophic failures to an interference engine design!
Has thanked: 1611 times
Been thanked: 4075 times
Can someone with VIDA post the part numbe r for these please?
Teddy1975
Year and Model: 2007 V50
Been thanked: 7 times
Post by Teddy1975 »
abscate wrote:Can someone with VIDA post the part numbe r for these please?
VIDA says: 974674.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
