Name that part!
Jazzer
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Post by Jazzer »
Hello again,
I'm looking to replace my fuel/evap system piece by piece (96 850 Platinum wagon, 197k) and I'm currently trying to find this part:
I want to say it's a check valve of some sort, between the manifold and the vapor canister purge valve. Can't seem to make out the numbers on my photo, and my eyesight is too poor to see it in person lol. I can't find it on any parts diagram; I see it pictured, but I don't see any number or description. Perhaps I can get a generic one somewhere?
Bob
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Between intake manifold and purge valve shouldn't be anything but a hose.
I would say that it's something that shouldn't be there...at least on n/a cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
101
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
I can't speak for a NA car, but on my 98 GLT I had to replace one of these valves as well. They are easily tested by trying to blow through it from both directions. If the valve is good, it should only pass air in one direction.
For the replacement, Volvo showed only an "assembly" that contained all the hoses for this system and the two check valves all together for something like $90. Um ... nope!
I ordered 1275226 - Volvo EVAP Check Valve, which was a direct replacement.
Again, I can't guarantee this is the part you need on a NA car.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Have one on my 01 C70. yes air passed only one direction. I did not have one on hand and did PCV system replacement without replacing it. Would have preferred to replace it
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
Been thanked: 504 times
Post by cn90 »
101 wrote:...I ordered 1275226 - Volvo EVAP Check Valve, which was a direct replacement...
This is probably correct PN.
Also, see the thread by sleddriver below:
viewtopic.php?t=54546&start=20
Jazzer
Post by Jazzer »
Thanks, guys. I forgot to mention that the platinum wagon IS a turbo, so that should clear up some confusion. I'll certainly check out the evap check valve part.
