2006 xc90 electrical gremlins
justind710
Year and Model: 2006 xc90 v8
Post by justind710 »
Hey guys new member here, I've had my xc90 for about a year now without much issues. I do all of my own work and just recently replaced my haldex pump, the pump was indeed bad. To my surprise though it didn't fix the issue and now I have many other multiple issues. I let my battery get low and I don't know if this contributed to the issue or no but I have charged it up by the car (it started on its own power). To start my central locking will not work, or my interior lights when I open the doors (work when I push the button) no running lights, rear door windows do not work and my awd.
I tested at the rem for my awd and no power if I apply power I do get my awd back, this made me assume the rem but all of the other circuits that don't work have power to them (also my brake lights work). I have checked all fuses and they seem to be good the only one I found bad was an inline fuse for my trailer lights that are after market, I replaced the fuse but no luck. I also removed the wiring completely and still no luck. I'm confused on where to look with out having a vida/dice. Looking for any hints or places to look? Ground? I think it's coincidence that it happened the same time I replaced my haldex pump.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Did you try to disconnect battery? But, put and turn key to second position before connect battery.
justind710
Yes, I did. I'm trying to get a dice set up to investigate further.
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Lets us know once you find out. Thanks. Also be sure battery is fully charged.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
