Transmission fluid type for my 2001 Volvo V70T
Hello all Aaron here coming to you from Monterey Bay Ca new to this site i have owned over eight different Volvos this is my newest yet owner of a 2001 Volvo V70T im changing radiator on the car lost a little tranny fluid diconnecting trans lines whay type of transmission fluid do i need to top it off after i reassemble everything? Also what type of coolant? Manual says AW5. Transmission oil ? Never heard of this i was also told dextron 3 and. ATF TOYOTA TYPE 4 ? Dont know whats in car now just bought it two weeks ago any advice appreciated thanks guys !
jbeebo
- Year and Model: S60, 2005
- Been thanked: 4 times
DO NOT use Dex/Merc tranny fluid. Proper fluid type is JWS 3309 which can be purchased from (of course) the Volvo dealership or the Toyota dealership as ATF Type4. Reason why you can use the Toyota stuff: Volvo uses an Aisan AW55 transmission, similar to that found in certain Toyota models. Aisan is the tranny manufacturer and they are the ones who specify the fluid type. Note, you can get it from IPDusa as well, click the link above to support this site: https://www.ipdusa.com/products/10543/1 ... nsmissions
Coolant is a dealer only item IMHO. The Volvo coolant is excellent and will give many many years of trouble and corrosion free service. You could use modern OAT type coolant from another manufacturer but won't save any $$ and might have some incompatibility so why bother. DO NOT use all-purpose coolant you'll find at O'Reilly's or other such auto stores.
https://www.ipdusa.com/products/11221/1 ... ze-coolant
Did you replace the o-rings on the tranny lines going to the radiator? Cheap insurance....
https://www.ipdusa.com/products/5777/11 ... l-kit-1999
And while I'm at it, Power steering fluid is not Dex/Merc type ATF. It's a special type; Pentosin CHF-11 or CHF-202. Surprisingly O'Reilly stocks Pentosin CHF-11 fluid.
https://www.ipdusa.com/products/5743/11 ... ring-fluid
2005 S60 2.4L (B5244S6), 175k miles
JRL
- Year and Model: Several
- Been thanked: 16 times
Mobil 3309 or Toyota Type 1V (same fluid) THAT'S IT!
JRL
He just needs to add a bit so why are you people giving him other options?
NEVER MIX FLUIDS, use 3309 or Type4 which is what is in there
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I've had good luck buying from here over the years. Watch out for sales- sometimes they have a case for about $10 less: http://thelubricantstore.com/mobil-atf- ... gQodU5EEhQ
Thanks for the reply everyone i did not replace the o- rings on transmission lines it seems like after i replaced radiator and lost a little tranny fluid the transmission now has very slight shifting flares coming to a stop more so in stop and go traffic and between 2nd and 3rd gear perfectly smooth on the highway and shifts fine as long as im not in stop and go traffic to long any help appreciated thanks !!
- 1678 Views
Last post by RickHaleParker
- 15 Replies
- 8465 Views
Last post by ggleavitt
- 3064 Views
Last post by Uree
- 1236 Views
Last post by jimmy57
- 1559 Views
Last post by jblackburn
