1998 V70XC - No spark after battery drained
T64me
Year and Model: 04V70R/05S60R/07S60R
Has thanked: 6 times
Post by T64me »
My 98 XC was left with the key turned to "on" and the seat heaters on. The battery drained. When I charged the battery and tried to start it again, it would not fire. When I checked for spark (with a fully recharged battery), there was none...
Could I have "cooked" my coil or something else by leaving the key in the on position until the battery died?
Has thanked: 1611 times
Been thanked: 4075 times
Possible but I doubt it, pull the coil wire from the distributor and clip it to a position near the engine block and see if you are getting spark when you crank.
dyn blin
Year and Model: 1997 850 Wgn
Post by dyn blin »
If your battery was under load long enough, it may have sulphated. If it is, it may seem to hold a surface charge, but the plates have been covered and allow only a small discharge, so the amperage and voltage won't be enough to start the car.
Try a new battery. You also may be able to jump start, but if the old battery is sulphated, you'll need to replace it.
'97 850 GLT Wagon- Driving to see 300k in the rearview
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Immobiliser kicked in.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha wrote:Immobiliser kicked in.
I think you are right misha.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
On a '98, there's only a starter cut.
And lights would be flashing and the
little horn would be trying to beep.
I'm thinking that if there's enough juice to spin the starter,
there should be enough to light up the plugs. Got a meter?
Time to start walking through the basics...
