Help with powering S60 seat -- Not in a Car Topic is solved
wadeatl
Year and Model: 2009 S60
Post by wadeatl »
I have a strange request for assistance on getting 12V power to a 2009 S60 passenger side seat. I am using the seat in an Obutto gaming cockpit that I use for race simulation. I would greatly appreciate if you can let me know what I need to run 12v from either a battery or a 12V power supply.
jbeebo
Year and Model: S60, 2005
Been thanked: 4 times
Post by jbeebo »
did you try searching for the wiring diagram?
5seconds on google found this.
30more seconds found page 98/199 schematic for the passenger side power seat.
2005 S60 2.4L (B5244S6), 175k miles
wadeatl
Post by wadeatl »
Thanks jbeebo ... I am usually pretty good with Googling but kept hitting a dead end with diagrams associated to this website. I am good with finding the BL-R and the SB on the connector (in the pictures). I am having an issue with finding what I need to do with the 4/56 and E-B thats in the drawing. It appears the 4/56 is supposed to be on the car under the dash of the car. I do not have the car so I am lost as to what I need to do for the 4/56?
Been thanked: 4065 times
You just need to put fused 12 volts on the green. And green black on the motor to move it. I can't see the colours on the other one but just trace the same motor wires in the forward/back and it should be intuitive
I've got a 2000 power seat in the garage and will see if I can take some pics today It might help if they used the same parts back in the last millennium.
Reverse polarity to move it the other way. No need for the CEM unless you are a glutton for programming punishment.
On edit - see better description below down thread
wadeatl
Post by wadeatl »
abscate ... thank you for taking the time to help me out. I had hoped to be able to use the switches on the seat. Are you saying that that would not work and I will need to manually wire each motor to a momentary switch?
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Just don't get too excited gaming in that thing...the air bags could deploy from the side of the seat! LOL :lol:
I think you should be able to use the seat switches ...can you find the bigger picture wire diagram and post here so we can noodle it?
By arrangement with Volvo Legal we can't host wiring diagrams here but posting a page for diagnostic purposes is fine
wadeatl
Post by wadeatl »
Thanks again abscate. This is the full picture of the diagram that I found from the link jbeebo. Again .. I appreciate your willingness to help me out!
Full Seat.JPG (60.89 KiB) Viewed 7537 times
wadeatl
Post by wadeatl »
Here is a better screen shot of the diagram ..
Screen Shot 2017-03-12 at 4.45.15 PM.png (64.14 KiB) Viewed 7524 times
jbeebo
Post by jbeebo »
I think there's a solution, but will require modification of the seat switch module. It looks like you'll need to bypass the "Stop Logic" circuit in the switch module. It also looks like the switches themselves control the high current for the motors.
I'd open up the switch module, bust out your soldering iron and take the 12V signal directly to each switch.
