98 S70 N/A 5-speed, Rear Spring Question: Correcting Rear-end Sag
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
I have no idea why I'm posting this right now since there will be so much snow on the ground in NYC that I won't be able to touch our car for a month probably. But it's always good to prepare, no? 8)
If you notice here, our car is taller in the front than in the rear. (The front has new springs from the Gabriel Readymounts.) And the rears are original.
I'd like to correct the rear end sag before I take the car for our Spring/Summer alignment. I just googled this and found these Proparts rear springs, Volvo Coil Spring - Rear (HD) - Proparts 43615822 https://www.eeuroparts.com/Parts/40677/ ... swodcC8J3g. I know, they're Proparts... But if it isn't rubber, how in the world could they mess this up? :lol: In all seriousness though, I see that these are for the V70, is there any reason why these wouldn't work on our S70?
Also, to rebuild the rear end, what else would I need besides this?
- Volvo Coil Spring Seat - Rear Upper - Genuine Volvo 3546435
- Volvo Strut Bump Stop - Rear - Febi 14916
- Volvo Spacer Upper - Genuine Volvo 1387907
Retired:
2015 Volvo S60, T5, 85K
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The front actually looks high to me as opposed to the rear sagging. The springs on the Gabriel struts are an unknown in the equation.
Springs are a black art and IPD are pretty much the Wizards when it comes to suspension on these cars. I have just under a million miles worth of P80 Volvos in the driveway and I have never replaced a spring. Unless you have a track car they don't typically wear out appreciably like the shocks.
theWIFES_S70
Ozark Lee wrote:The front actually looks high to me as opposed to the rear sagging. The springs on the Gabriel struts are an unknown in the equation.
The front is so high! I should take a photo measuring it. It's at least two inches higher! I guess this isn't a very crucial update that needs to happen. When I went to replace the struts, I couldn't get the springs free from the original struts and the shop I took them too couldn't get them off either... So in the end, I just went with what I could to get the job done. I was imagining that putting "new" springs in the rear would raise the car a little and make it more "even." But I'm not ready to spend $50 a spring. Especially when there are these $20 V70-only ones.
Thanks for the insight, Lee!
Retired:
Been thanked: 4069 times
My 1999 springs definitely sagged but I tow boats. They arent heavy, like 500#, but when I replaced my springs I got 1-2 inches of ride height back
I posted this in a thread, too... ill search
viewtopic.php?f=1&t=63781&hilit=1999+ride+height
I got two inches of sag back from the rear with new springs - ride is great.
I went with IPD blues. The rear springs are actually really easy to do - as long as you don't get into delta links.
Has thanked: 2205 times
Been thanked: 1852 times
The only reason I have replaced the springs is if they break or are badly rusted and I am going to be working in the area. I had a set of rears on the 'R' powder coated, but noticed shortly after the car seemed to droop at the rear. Replacing them brought the car back to normal height. However, in the case of your car, I agree with the others that the fronts look high and the rears look fine.
theWIFES_S70
Thanks for the insight fellas. I might get some rear springs to see if I can correct the angle. We do need the write up, no? I have a trip to Montreal coming up and over the course of 800+ miles, it might be nice to see some improvement in gas mileage...
But then again, I might have to focus on the other clunks... Ah, NYC...
Retired:
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
theWIFES_S70
Wow... this is our saggy rear-end exactly!
But $129 for the pair??? :|
Retired:
tryingbe
Post by tryingbe »
I can sell you a set of Volvo OEM spacers and bolts to raise up the rear. There are washers in place so the springs can't wander off.
85 GLH, 367 whp
00 Insight, 72 mpg
Measure from ground to lip of fender and compare to my numbers. That does look droopy.
Don't forget to stop in on your way to MTL.
