I change the oil every 3,000. I use Castrol GTX primarily. A few times Valvoline has been used.850 LPT wrote:Your PCV system is probably still fine at that mileage if you were diligent about oil changes, but it never hurts to check. Do the "glove test" for peace of mind.
What should I invest in to check/repair
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
viper69
Thanks. I wasn't aware of this. I know at some point some sort of front rod related to the wheels was replaced with a rebuilt one. I'd have to look up my receipt to know for sure.erikv11 wrote:The factory front suspension tends to fall apart in the 110k - 150k range. Check out the control arms, tie rod ends, sway bar end links, struts and spring seats.
It's been a one owner car, my family bought it. So I'd like to make sure it keeps going for as long as possible.
On that note, the I have a leak in the windshield washer fluid, not happy as I know where the tank is located, at the bottom on the front right/passenger side. I bet it cracked. If I can find the leak, I will see if I can use some type of expoxy to seal over it. I don't feel like shelling out money for that repair job.
Volvo 850 GLT 1995
viper69
Yeah I'll look and see what was done. I know the timing belt was done, and I recall people telling me here to get other work down like you mentioned above. I think at the time however either I DID do it, or I didn't due to funds.magna224 wrote:They both have great ideas. Freshening up the suspension will make you love your car even more unless somehow it's managed to hold up exceedingly well. You can do with a poor ride for a while but you can't do without a timing belt though. I'd say to do the timing belt and water pump first and suspension next. My pump blew at 140k while my other car I don't think ever had a new pump its entire 300k mile life. If you do the timing belt might as well get everything down there taken care of too.
Volvo 850 GLT 1995
viper69
I've got a question for anyone.
Is the trunk light supposed to go turn on automatically when the trunk is opened? I can't remember if this is one of the quirky "features" from the Swedes that actually doesn't function the way we expect it to here in the USA.
Volvo 850 GLT 1995
viper69
Heater core replaced less than a year ago.splats wrote:Maybe the heater core - I needed to replace mine when I got it with 140k miles on it.
(I agree with timing belt first.)
Volvo 850 GLT 1995
viper69
oragex wrote:Worth inspecting the above along with the dust booths at the steering rack. If any of these are still good, no need to replace them now, these are quite easily replaced later on.erikv11 wrote:The factory front suspension tends to fall apart in the 110k - 150k range. Check out the control arms, tie rod ends, sway bar end links, struts and spring seats.
The most important thing to know is which replacement brands should be used. Read here on forums.
Yours being a non turbo, you need to remove the air box thermostat and set the flap for cold air, similar to this
The PCV must be inspected by now.
Regardless of the condition, I would replace all 4 shock absorbers along with the front spring seats: very important to buy only the brands people recommend here for these parts.
I'd remove the serpentine belt and inspect by hand the alternator, a/c compressor and tensioner pulleys.
Replace the coolant thermostat if original.
I'll look into those. I know one of the dust boots was replaced with new back in about 2011 I believe, the other was fine.
I should do the shocks, I honestly can't remember when they were done last. I'll have to take a look to be sure.
What brands do people recommend for shocks? And what model of shock too? I've never been very good at knowing shock info.
On the alternator, what do you mean by inspect it by hand?
The A/C compressor has been checked, done when the heater core was replaced. The tensioner pulleys checked too, back in 2014.
Volvo 850 GLT 1995
tryingbe
- Year and Model: None
- Been thanked: 26 times
Volvo recommends timing belt every 70000 miles.viper69 wrote:Not long ago. I checked yesterday, I have 80,000 miles to go on that.tryingbe wrote:When was the timing belt/waterpump last changed?
http://volvo.custhelp.com/app/manuals/O ... om_id/1111
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- Been thanked: 4068 times
Nice catch tryingbe
Its 70,000 miles/ 7 years first occurring on the 1995 models, correct.
How is the car riding? If you are on good roads, the suspension can last longer than 100k - there is no reason to replace it if you like the ride and the tires arent wearing out. One easy measurement is the ride height - this will give an indication of your spring wear, which will tell you how hard the suspension has been used. Measure from flat road to bottom of fender well, report and have people compare. I gained something like 1-2 inches when I did my 1999
- Has thanked: 311 times
- Been thanked: 817 times
Yes it is supposed to go on. But there is a little switch on the trunk light too, make sure the light is switched on.viper69 wrote:I've got a question for anyone.
Is the trunk light supposed to go turn on automatically when the trunk is opened? I can't remember if this is one of the quirky "features" from the Swiss Swedes that actually doesn't function the way we expect it to here in the USA.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
The switch for the trunk ligh has a tendency to move to the off position on my wagons and the sedan as well.
Btw, replace the PS fluid just to be safe.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 811 Views
- 1451 Views
Last post by oragex
- 777 Views
Last post by RickHaleParker
- 1587 Views
Last post by CIK7
- 886 Views
