Wire under the Air Cleaner
There is a wire under the air cleaner of my 96 Volvo 850, and the connectors that clamp together came loose, preventing the car from starting. I re-connected that connector, but the connector ends are degrading. I Gorilla Taped it up and zip tied it and it aint "pretty", but every now and then, the car won't start and I have to push the connector ends together to get her to start. Can this wire just be direct connected with removal of the connector ends and soldered together, so I don't have to worry about it falling apart? I don't know what it's called, but this wire goes from the back of the engine on the air cleaner side, to the front, with connectors on each side of the wire, that connect together. The connectors are just crumbling and I'd like to know if the wire can just be soldered together and taped up to prevent it from separating? Appreciate the feedback.
96 Volvo 850 GLT/NA-Green @312,298 miles
Stage 0 Tuneup w/Cold air side/open flap air box mod
Pro Parts Sweden Exhaust manny/DEC Cat/Starla Exhaust/SS Tip
Hard Rock guitarist with Solo project, driving a Swedish Death Metal Machine. http://darkblu.com
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Can you get a picture? I am having trouble knowing which wire you speak of.
You say back of the engine- you mean a braided wire (ground wire)?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Me too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 316 times
- Been thanked: 531 times
+1, a picture would be very helpful. There are a few connectors in that area of the engine bay.
Could it be the connector for the hood alarm switch? When the car fails to start, is it not cranking (starter not turning?)
Could be, but I don't think that would affect the car running.abscate wrote:Could it be the connector for the hood alarm switch? When the car fails to start, is it not cranking (starter not turning?)
I don't "disconnect" the wire. I don't have to. When the two de-composing ends start to separate, the car won't start. When I go under the hood and press them together, the car starts. I have pic:beigg wrote:once the car is started, when you disconnect that wire while car is idling, does the car shut down?
http://oi64.tinypic.com/294tqm9.jpg
It's the Black Wire with the Zip Ties. I can't do a better pic than that, without removing the air cleaner assembly and I couldn't do that today, due to rain.
That looks like a heavy current wire powering one of the fuse boxes?
Yikes
Yikes
Looks to me like the wire for the crank sensor. Is the connector white?
That's DEFINITELY something that needs to be replaced. I wouldn't mess with splicing wires for a vital sensor like that, because you could mess with signals and cause more no-start issues.
- 10 Replies
- 2235 Views
Last post by volvolugnut
- 1106 Views
Last post by crisnumbertwo
- 1616 Views
Last post by oragex
- 16 Replies
- 2157 Views
Last post by Marty27
- 15 Replies
- 8419 Views
Last post by Jewl1215
