Hi there. I've got a 2005 V70R that's developed a vibration that I feel through the clutch pedal that can be felt on start up and when shifting at around 1500 to 2000 RPM's. The clutch doesn't feel like it's slipping since the rattle started. What I was wondering (hoping) was if it could be the lower motor mounts that were finished since I recently changed the upper mount and the shock brace bushings. I'd really appreciate any feed back anyone can give.
Thanks.
Rattle in the clutch pedal in low RPMs
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Maybe through-out bearing...is the issue.V70r carbon wrote: 27 Mar 2017, 20:352005 V70R that's developed a vibration that I feel through the clutch pedal
V70r carbon
- Year and Model: 2005 v70r
Thanks for the idea and it's completely possible that it's the throw out bearing but I think that i'd feel it throughout the revs. When the clutch is depressed at idle, it feels normal,
when I give a tap on the gas is when I feel it when the revs get between 1500- 2000 range. Thanks.
- 1392 Views
Last post by alschnertz
- 1252 Views
Last post by Turbolena
- 2208 Views
Last post by RickHaleParker
- 659 Views
Last post by brunocerous
- 860 Views
Last post by JLv70t5
