New to me V70, couple questions... Topic is solved
Slum88
Year and Model: 1998 V70
Post by Slum88 »
So this is my parts list im ordering today:
Oil Filter
Fuel Filter
Polyurethane Upper Engine Stabilizer Mount
Engine Air Filter
PCV Breather System Kit
2 Corteco Rear Camshaft Seals
5 Bosch Spark plugs
Anything else?
These parts are just to get the car running again...
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Wow that is a Frankenstein of a Volvo you got there, glad you are restoring it to its OEM former glory. :oops:
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 311 times
Been thanked: 817 times
There is a long saga on the forums about PCV parts. If you already know about it fine, if not you may want to do a little searching/reading. One key is never buy the full aftermarket kit, the hoses are crap. But you can get by with just buying a few of the Volvo hoses, too.
Is the port into the block clear, at the bottom of the oil trap?
If the PCV isn't blocked somewhere, then there could be a more insidious problem, like blowby due to excessive ring gap. You would want to test compression, but that's a hassle now that the intake and PCV is all apart ...
Has thanked: 1609 times
Been thanked: 4065 times
Only one knock sensor !!
Ha!! Metal part of the oil tank lowest hose faces block! In your face you hosers!!
Trap. Oil trap, hoser.
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
OP could still run a compression test, just excite the starter with a battery. It might be the lighting in the photo, but look at cyl #4 valves, it looks bent to me.
Also, place a large piece of cardboard under the block and spray some degreaser on the block. Check the starter terminals for corrosion (green stuff), as well as any ground wires not visible with the manifold on .
I am sure an oil cap gasket would do wonders for oil on top of the engine.
Klaus
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
Be kind to yourself and go OEM with the upper torque mount. The poly versions will transmit more engine vibration.
M1 10W-30 HM
Slum88
Post by Slum88 »
sleddriver wrote: 30 Mar 2017, 11:31 Be kind to yourself and go OEM with the upper torque mount. The poly versions will transmit more engine vibration.
Oops, went with the IPD poly mount, we'll see how it feels.
Slum88
Post by Slum88 »
Parts are on the the way and coming...
The ignition and key assembly arrived yesterday and I was having trouble getting the shear bolts off. Any ideas guys?
Got the ones out of the new assembly by using a large vise grip and wrench for torque.
How am I supposed to get these out?!
Klausc
Post by Klausc »
I suggest using a punch and a ballpene hammer to get the screw to turn. I am surprised to see blue locktite on the screws that came with your new lock. Does the new key work in the door and glove box?
Klaus
