2004 XC90 T6 CEL misfire codes very rough idle Topic is solved
xavif310
Year and Model: 2003 XC70
Post by xavif310 »
Hello, I have a 2004 Volvo XC90 T6. with 100k miles. The CEL is blinking. Checked codes and shows misfire in 1,4,6. I changed, coil packs and same. I changed the spark plugs, same. Changed injectors and same problem persist. If I let it idle, it sounds really rough. I dont know where else to check. Thank you
Reason: No "Help" in titles please. Edited title.
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
MAF ?? or Vacuum Leak?? Just throwing out some ideas
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
xavif310
Post by xavif310 »
Is there a certain procedure to check the MAF? Also, how would i go about performing a vacuum leak test? aside from visually inspecting. Thank you
cuhfs
Post by cuhfs »
First...all advice below... is at your own risk since I have not done them on the XC90... but here is what I have done on my other cars to test MAF. Unplug it and if car runs the same then it is the MAF thats bad.
Vacuum lines Start with visual and audible for the vacuum lines. There are ways to test vacuum with a tester or with smoke or with carb cleaner spray but you would have to research those yourself (youtube) or maybe someone else could weigh in on that stuff... and you decide if that's what you want to do. With carb cleaner I believe if you spray by a leak car will run better or worse for that second while the spray is there hence indicating a leak.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
