My plan was to replace nearly everything but I hadn't considered the parking brake cable. We get nearly no corrosion in Atlanta. Its possible that the cable is worn but unlikely that it has anything other than minor surface rust. Is there any benefit to changing the cable out at the same time in saved effort?scot850 wrote: 28 Mar 2017, 19:29 Not sure what gets included with the Cardone calipers these days. Some calipers come with refurbished caliper brackets, pad retainer springs (on the front) and slider pins at the front (FWD) and rear (AWD). Only thing to watch for is the quality of the bracket re-furbishing and the rubber slider pin rubber is usually of a poor quality as are the replacement slider pins. If You have the last 2 items in your Volvo kit I'd swap them out from the rebuilt units.
Otherwise it is good to go.
On the rear parking brake cables, read my recent warning on the use of Pro-Parts Sweden cables (rubbish) and the fun installing the new cables at the rear hub. A dremel came in perfect for removing the built up rust in my rear hubs to allow the new cables to slide in with a little Vaseline.
Finally, don't forget to use the tieback plastic straps for the parking brake cables (again see the thread mentioned above).
Good Luck!
Cardone brake calipers front and back
98v70dad
- Year and Model: 98 V70
- Been thanked: 4068 times
In the rot free zone they should last forever. My 99s are original in the rust belt!!
- Has thanked: 2202 times
Best thing is to look at the cables just rearward of the mounting point in front of the rear wheels. The cables tend to split the outer sheathing at that point and then moisture gets in, also the cables can fray at that point. Once you have everything stripped down, get someone to gently pull the parking brake lever and then release and feel if the cable is dragging and releasing easily. Hopefully you may not need them if rust is not an issue in your area. Again some people rarely use them so again they may have minimal wear. It is not a huge job to have to do them at a later date.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
It doesn't take much extra effort to swap the handbrake cable later. The majority of the work for that job is in tearing up the interior; removing the caliper and rotor to swap the cable end is trivial by comparison.
