Help with fuel line coupling on fuel rail
bikerbob951
Year and Model: 2006 XC70
Post by bikerbob951 »
Hello all, I've been lurking for a while, and I've run into an issue. I'm performing the PCV system replacement on my 2006 XC70, and I'm having a great deal of difficulty with the attachment between the fuel rail and the fuel line. The style I appear to have is the one on the right in the below photo:
I've removed the outer clip with the T-15 screw, but I can't figure out how to separate the line from the rail! I see where people mention an A/C and fuel line removal tool, but it just doesn't look like that will work here. Am I missing something? I need to get this car back up and running ASAP, so any assistance is much appreciated!
Here's a photo of my car, in its natural habitat.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You need a special tool
goldxc70
Year and Model: XC70 2004
Has thanked: 27 times
Been thanked: 3 times
Post by goldxc70 »
Reading elsewhere, I thought the special tool was required for the type of connector used prior to the ones shown above. But, as always, I recognize JRL's vastly greater experience that mine.
On my 2004, XC70 I have the Old Style one pictured above which according to IPD is prone to failure. When I looked at it for another reason a small piece came away in my hand so I think it may be sensible to change to the new style.
zjevik
Year and Model: S60 2006
Post by zjevik »
I did my PCV job two years ago and I disconnected it without any tools. I don't remember how exactly I did it but you have to take the top piece with screw out and then the fuel rail will disconnect. Just make sure you release the fuel pressure first.
Here is what VIDA says:
fuel line.png (90.49 KiB) Viewed 5125 times
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The new style, I removed one at a scrap yard like in the picture above: remove the screw, then lift the clip of the plastic part that keeps the screw (the clip is seen at the right) and slide this part off, then the line is disconnected. Just used my hands, easy to do.
bikerbob951
Thanks for the responses everyone. Can confirm, I don't believe any special tools were needed, although I did use a fuel line decoupler. I haven't examined the clip, but I don't think the decoupler did anything really.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Recently done on my 2006 XC90 when doing the PCV. I struggled with it because I was afraid of breaking it then realised it all slid apart after the screw removal as per Oragex' post.
