Dear Forum,
the transmission fluid in my '97 V70 na is somewhat over max. As far as I can tell from the indicator stick, readings differ depending on orientation, but it always indicates to much.
It's been like this since 25k km now, since I got the car. I wonder if I should do something about it, planning to change fluid anyways at some point, though.
Transmission works normal, can feel shifts from 1th to 2nd, otherwise smooth.
Opinions?
Thanks!
Caspar
Automatic Transmission Fluid '97 V70 na
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Hi Caspar, the amount of fluid that drains out of these transmissions is pretty consistent. And considering how old our cars are, I think you certainly couldn't cause any damage by draining it and then refilling it with the correct amount. In fact, your transmission would probably like that. I'd be inclined to do a drain and fill.
Retired:
2015 Volvo S60, T5, 85K
You need to follow the procedure to check the level precisely, Caspar. Check your owner manual for the conditions of the check, it is completely different than checking the engine oil.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Are you checking with the engine running or off?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 1153 Views
Last post by Krons
- 866 Views
Last post by difflock54
- 3334 Views
Last post by pmondrian
- 1415 Views
Last post by RickHaleParker
- 1211 Views
Last post by Georgeandkira
