The previous owner did a timing belt job (belt, tensioner, rollers, waterpump) sometime after 200k miles, so hopefully it's none of that. The serpentine belt looks good and isn't loose, but I do see a lot of microcracks forming on the friction side. Oil level is almost to the max line on the dipstick. Hoping it's not anything inside the engine or the turbo. I really have no clues at this point. tried searching the forum, but "screeching noise" is not a whole lot to go on. Was hoping one of you much more experienced members than I could provide some insight. If I can't make any headway, then I'm calling the mechanic down the road and kissing my paycheck goodbye for his "expert" opinion. This car is my only source of transportation, so I really need it to be in working order.
'98 S70: Screeching when Reving at Cold Start
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
My 1998 S70 T5M has now hit 250+k miles. This summer, I started hearing a loud, low-pitched screeching noise (not high-pitched like a loose fan belt) whenever I would press on the accelerator. So I know the noise is RPM related, I think it might be a bad bearing, but I cannot trace the source. My best guess/hope is it's one of the pulleys on the serpentine belt. The noise would go away after the engine warmed up, sometimes quickly or sometimes slowly, so I wasn't too worried about it at the time and I was not doing much driving. The noise doesn't change whether in gear, in neutral, clutch engaged or disengaged. I think it is somewhat dependent on ambient temp: when its cold out it is quieter but takes a long time to go away, and when it's warm out it's much louder but goes away quickly. Some days I do not here it at all, and never hear it when my mechanic friend pays a visit (of course
). It can only be heard whenever I give the engine some gas, it is not apparent at idle or even when coasting in gear. Today it was extremely loud to the point where I could not hear the exhaust over the screeching, so parked it stays for now. I can't for the life of me figure out what the noise is and have been unable to get a usable recording of it.
Knows enough to be dangerous
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
If it were me I'd check the alternator, power steering pump and idlers/tensioners for play. Just remove the serpentine belt and wiggle them. Also try turning them to see if they're binding.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
That's exactly what I was thinking. Just because the timing belt was done, doesn't mean it was done right or with the right parts. (And being that a "bargain basement" Rockauto timing belt kit is a 25k-35k stopgap.) I might be inclined to replace the timing belt (it shouldn't be developing any cracks) and all the idlers. But yes, before you do all that, take off the serpentine belt and see what they sound like and if they have any play.wizechatmgr wrote: 02 Apr 2017, 15:15 If it were me I'd check the alternator, power steering pump and idlers/tensioners for play. Just remove the serpentine belt and wiggle them. Also try turning them to see if they're binding.
Retired:
2015 Volvo S60, T5, 85K
- WhatAmIDoing
The prev owner says it was a kit from IPD, but you never know. Was hoping to make it to at least 260K before thinking about a timing belt change. Unfortunately, I am away from home with only a set of Torx bits with me, so I'm going to have to make friends with a guy with tools. My original suspects were the power steering pump and alternator. I'll see if I can scrounge up something to get the serpentine belt off.
- theWIFES_S70
If you have a 1/2" ratchet/breaker bar and a couple of coins, you can take off the belt pretty easily. Good luck in troubleshooting the noise. You should grab a long screwdriver and stick it to your ear and place it near all the pulleys; it might be one of those, you never know!
Retired:
- WhatAmIDoing
I have a small ratchet. Might pick up a long screwdriver. But if I can't find someone to work with me to step on the accelerator, might end up with the mechanic anyway. Wish I had a 10mm socket to get the timing belt cover off, just to make sure it isn't getting shredded due to a bad bearing. And it's not like I can drive to harbor freight....
- Been thanked: 4067 times
Get a piece of garden hose and use that to listen to your engine and isolate the noise. You do want to nail it down as to location
..but when your neighbors see you walking around with hose stuck in your ear, they will never bother you again..
1998v70xcbill
- Year and Model: 1998v70xc
- Been thanked: 3 times
I get this noise when cold sometimes. Goes away after warmup. I thought is was a bearing noise also. I still have the noise, and
I believe it is the oil thermostat for the oil cooler. I don't let it bother me anymore. But boy did it, when I didn't know what it was.
