Does this look right to you?
Jazzer
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Post by Jazzer »
Hi guys,
I got my struts replaced last November along with new mounts, etc. on my 96 850 wagon. Now that it's springtime, I'm just noticing now that the struts seem to be sitting kinda high...it also looks like the top washer is upside-down; if so, is that repairable without removing the entire assembly? There is also a gap that doesn't look right, but that may be because of the top washer being inverted. Ideas?
Bob
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Just undo that upper bolt and install the washer properly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 311 times
Been thanked: 817 times
There is supposed to be a gap even when the washer is on the right way. Yes the washer is upside down and what misha said - go ahead and turn it over.
I can't be certain from the pic but hopefully you will find a cross0shaped nut underneath, like this:
Jazzer
Post by Jazzer »
Thanks for the pic, that will be a good reference for me just to make sure my mechanic didn't totally screw it up...
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Flip the washer around. As long as the cross nut is in place, you should be able to safely remove the top bolt and flip the washer. For some reason mechanics never put those on the right way on these cars.
shegarty
Year and Model: 1998
Has thanked: 12 times
Been thanked: 8 times
Post by shegarty »
After you fix it yourself make a mental note to find a different mechanic or bone up on those skills yourself. If your mechanic can't do a simple strut replacement right I wouldn't trust them to change the oil.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The top rubber stop plate is upside down in the first picture.
bmdubya1198
shegarty wrote: 06 Apr 2017, 10:12 After you fix it yourself make a mental note to find a different mechanic or bone up on those skills yourself. If your mechanic can't do a simple strut replacement right I wouldn't trust them to change the oil.
+1 to this. Pretty ridiculous that a mechanic can't figure out a strut.
Jazzer
Post by Jazzer »
Hey guys, I finally got around to attempting to flip these caps over, and I see that the mechanic also over torqued one of the nuts to the point that it is slightly cracked. I have not been able to locate replacement nuts at any local parts places; anybody have a good place where to order them? They are Bilstein Touring struts with a 22mm shaft. Thanks!
bmdubya1198
Check FCP.
