Anyone heard similar to this before and can point me in the right direction?
My V70 1999 2.4 Sounds like a Tractor - why?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Could it be a very loud serpentine pulley? Such as the a/c one. Does the sound go away without the belt (you can run the car at idle 1-2 min without the belt on). Another way to locate a noise is to use a 2-3ft tube (I use a shower hose) and carefully approach one end to the engine while listening to the other end at the ear.
- Has thanked: 2199 times
I would suggest one of 2 things:
1) Cracked exhaust manifold or failed gasket or broken flex-pipe in the downpipe. Rev'ing may just cover this issue.
2) More concerning may be lack of oil getting to the head. Raising engine speed may just increase oil flow to starved top end. Try running a thicker oil to see if it helps. The issue may be the oil pan 'O' rings have failed not allowing oil pressure to the head until higher revs.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Sounds like a bad crankshaft pulley balancer. I heard the same noise on 2 family Buick 3800 engines and a friend's Ford and in all 3 cars the balancer had broken lose of the pulley the serpentine belt runs on. All 3 cars only made noise when idling and noise went away when rpm was increased. All 3 cars were normal after replacement and all three balancers had the rubber bushing between the balance weight and pulley was gone also with the engine off you could hand move the serpentine belt a few inches back and forth by hand between the stop pegs. Worth checking, June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Thanks June - sounds promising... will check and report backJune wrote: 06 Apr 2017, 16:32 Sounds like a bad crankshaft pulley balancer. I heard the same noise on 2 family Buick 3800 engines and a friend's Ford and in all 3 cars the balancer had broken lose of the pulley the serpentine belt runs on. All 3 cars only made noise when idling and noise went away when rpm was increased. All 3 cars were normal after replacement and all three balancers had the rubber bushing between the balance weight and pulley was gone also with the engine off you could hand move the serpentine belt a few inches back and forth by hand between the stop pegs. Worth checking, June
1999 V70 2.4 SE - UK
2008 XC90 V8 4.4 Executive - UAE
- 12 Replies
- 3413 Views
Last post by CNGBifuel
- 807 Views
Last post by Sommerfeldt
- 12 Replies
- 3798 Views
Last post by jvl
- 24 Replies
- 10791 Views
- 2734 Views
Last post by BlackBart
