Hi guys,
I got my struts replaced last November along with new mounts, etc. on my 96 850 wagon. Now that it's springtime, I'm just noticing now that the struts seem to be sitting kinda high...it also looks like the top washer is upside-down; if so, is that repairable without removing the entire assembly? There is also a gap that doesn't look right, but that may be because of the top washer being inverted. Ideas?
Bob
Does this look right to you?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Just undo that upper bolt and install the washer properly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
There is supposed to be a gap even when the washer is on the right way. Yes the washer is upside down and what misha said - go ahead and turn it over.
I can't be certain from the pic but hopefully you will find a cross0shaped nut underneath, like this:
- Has thanked: 316 times
- Been thanked: 531 times
Flip the washer around. As long as the cross nut is in place, you should be able to safely remove the top bolt and flip the washer. For some reason mechanics never put those on the right way on these cars.
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
After you fix it yourself make a mental note to find a different mechanic or bone up on those skills yourself. If your mechanic can't do a simple strut replacement right I wouldn't trust them to change the oil.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The top rubber stop plate is upside down in the first picture.
+1 to this. Pretty ridiculous that a mechanic can't figure out a strut.shegarty wrote: 06 Apr 2017, 10:12 After you fix it yourself make a mental note to find a different mechanic or bone up on those skills yourself. If your mechanic can't do a simple strut replacement right I wouldn't trust them to change the oil.
- Jazzer
- Year and Model: 1996 850 Turbo
- Has thanked: 2 times
Hey guys, I finally got around to attempting to flip these caps over, and I see that the mechanic also over torqued one of the nuts to the point that it is slightly cracked. I have not been able to locate replacement nuts at any local parts places; anybody have a good place where to order them? They are Bilstein Touring struts with a 22mm shaft. Thanks!
Check FCP.
- 3955 Views
Last post by oragex
- 1208 Views
Last post by oragex
- 564 Views
Last post by erikv11
- 10 Replies
- 1675 Views
Last post by cn90
- 14 Replies
- 2372 Views
Last post by sleddriver
