Rear cam seal, now pcv system - what else should I take care off when pulling apart?
Overland_XC
- Year and Model: 1998 V70 XC AWD
More nice info. I'm in the process of finding all vacuum hose to replace and anything else that looks suspect.
Overland_XC
Can the white and purple hose be replaced with normal vacuum hose?
- Has thanked: 311 times
- Been thanked: 817 times
Yes, both can. All plastic lines can be replaced with rubber lines. Try to match the inner diameters, more or less.
Overland_XC
Thanks!erikv11 wrote: 10 Apr 2017, 19:57 Yes, both can. All plastic lines can be replaced with rubber lines. Try to match the inner diameters, more or less.
Overland_XC
Finally finished pcv, new vacuum lines and started with no check engine lights. Next thing I know oil is spewing from lower oil cooler line! Anybody have part numbers for upper and lower? Is aftermarket ok? Becoming quite the project
Bummer, that oil cooler line job is probably my least favorite. Be careful with the rectangular oil cooler thermostat.
Check out this post and the link therein, you don't have to buy Volvo lines: viewtopic.php?f=1&t=80837&p=436468#p436468
But also, do NOT buy aftermarket. These four options are all good for quality, much better than buying Dorman or other aftermarket brand: Volvo lines expensive, buy custom rebuilds from orleec, have the local hydraulic shop make rebuilds, rebuild them yourself.
- 1126 Views
Last post by Ben850
- 684 Views
Last post by 850 LPT
- 4677 Views
Last post by oragex
- 1483 Views
Last post by iRenaissanceMan
- 13 Replies
- 3299 Views
Last post by bjack56
