2000 S70 lit like a Christmas tree but no codes? Topic is solved
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
I've been working double shifts and I've not had time to work on the car but it drove great today, great acceleration, cruises at 75 mph nicely and all 4 speakers working great and only the solid up arrow. Tomorrow it will be a different story I'm sure as it was yesterday.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
so, quick follow up to a "new" symptom. Started it up to leave work last night and it acted like I was pulling a large boat and up a hill. No matter how far I depressed the gas peddle, it would just slowly creep until I got to highway speed where it drove fine at that speed but once I slowed down it took forever to accelerate. No jerking or hesitation, just slow moving and no passing gear. Stopped at 7-11 and when I came back out and started it up all symptoms were gone. Once home, I sprayed carb cleaner all around all the throttle body areas and found no leaks, cleaned the MAF and no difference. Unplugged MAF while engine was on and it immediately died. Drove normally to work this morning with same lit dash and sporadic hesitations. I guess I'll pick up an ETM and just bite the bullet.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- Has thanked: 2200 times
The slow response to accelerating (assuming the orange arrow is on) is the car is in limp mode. Basically it goes to about 3rd gear, perhaps someone could chime in on that one.
ETM can also cause the issue if it is not getting a position signal so again will give the slow response to accelerating.
aaron1611
yes, the up arrow was steady, not flashing. Still no ETM dash light and I'm still confused as to why it's not throwing any codes. Could my OBD11 port be non functioning? It reads my car etc, but just doesn't throw any codes. I'm going to try to work on it later today. Thanks again for all the input so far.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Try reading the monitor readiness, then reset by disconnecting the battery and seeing if the monitors go not ready to test OBD port
aaron1611
so, an update. I purchased a new MAF and installed it and as soon as I started the engine I immediately got the ETS light. While sitting in the driveway feeling frustrated, all the other CEL's were coming and going as they do and I figured that I would check my primary from battery to fuse box under the hood . Even though it looked fine I pulled it out and all 4 of them in the harness were shot, sheathing melted off, corroded and splintering. Could this be my problem the whole time? I replaced it and put it back together and stared up the engine and zero CEL's!! About 10 mins into my test drive with everything working great, everything returned as normal, all the same lights, no odom or speedo etc. but no ETS light since. I went back to check for codes and I finally got one!! P0600. Seems to be much said about this code but I'm not finding a "one" solution. I'm holding off on getting the new ETM but I guess I want to know what to do next. Thank you.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
oops. ordering new ETM and will post back results.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Your P0600 is an ECU comm link code....but.......it's not your ECU. Root cause is probably bad 12V supply somewhere
Wiring on these cars is very robust. What caused the burned wires on the primary supply side?
aaron1611
I don't really know why the primary was shot up underneath the fuse box but it was the same way on my V70 too. Everywhere that I can check with my meter is 14+v, took the Napa battery up to be checked, had alt. checked and both are good. On a side note, I lived in NYC for about 10 yrs and loved it.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- 1453 Views
Last post by oragex
- 676 Views
Last post by jreed
- 1408 Views
- 1048 Views
Last post by shiloh51933
- 10 Replies
- 2691 Views
Last post by erikv11
