Alarm Service Topic is solved
Radmeister
Year and Model: 2001 XC70
Post by Radmeister »
There are a few posts on this site regarding the alarm siren, servicing it at the dealership, and dyi fixes.
I just want to share my experience. Drove around for about 4 years with the service alarm message, never really bothered me much. Then as prophesized by the dealer my sunroof stopped functioning. So I figured it was time I got the software delete of the alarm system as it seemed like too much work to either replace the siren myself or dyi it.
So I got the software delete, service message gone..OK...Still no sunroof. From my observations once the sunroof is gone forget dyi and a simple software remove, the PCB in the siren is busted. Even if you do the software eventually your sunroof will stop working.
You have to disconnect the siren module after the software. In my case cut around one of the wheel well rivets and pry it enough to get a pair of scissors in there and cut one wire at a time.
If the battery explodes and melts your control board in the siren the software won't do anything on its own.
Coincidentally the loud screeching i heard Everytime I hit the windshield washer fluid through the speakers went away once I cut the wires. Nice ground fault through that PCB.
So if you decide to get the software delete get the dealer to disconnect the siren module too otherwise all you are saving yourself is the 5sec message on start-up. Eventually your sunroof will stop working.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Didn't know about a software thing. Just disconnect the siren alarm.
Legofan
Year and Model: 2001 S80 T6
Post by Legofan »
oragex wrote: 15 Apr 2017, 18:51 Didn't know about a software thing. Just disconnect the siren alarm.
What will that accomplish? The sunroof still won't work and you will still get the message i've been told. Did disconnecting it fix both issues? Currently I have the message and my sunroof doesn't work.
2001 S80 T6 Moondust sent to auction for scrap
AlbertoHanna
Year and Model: 2001 v70xc 2.4 t
Post by AlbertoHanna »
Hello, I have a Volvo V70XC 2.4 T 2001, sometimes the alarm goes off with the car parked.
What can be the problem?
