Oil leak behind cap
I was getting some misfires on 3 cylinder's so first thing I checked was the distributor cap, I found some oil and dirt under the cap so i cleaned it up and reinstalled no more misfire.I am assuming there is a seal behind the cap that is going bad and leaking oil. They much to get in and out?
Tom Hood
- Has thanked: 311 times
- Been thanked: 817 times
That's the rear cam seal and it is super easy to change. Best bet is to buy only Corteco or Volvo brand cam seals, many aftermarket brands fail quickly. There is also one on the exhaust cam, also easy to change maybe do them both.
Front cam seals are much more involved and failure is less common.
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
viewtopic.php?f=1&t=50752 <- how-to
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- Has thanked: 2197 times
- Been thanked: 1850 times
Often these begin to weep when there is too much crankcase pressure. When was the PCV system last serviced? If you don't know then a simple test is the rubber/latex glove test. Remove the oil filler cap and hold the glove over the oil filler hole. Get someone to start the car and see what the glove does. If it inflates the system is pressurising and that is what helps (old) seals to fail as it forces oil past the hard old rubber seals.
Let us know how you get on.
+100 to Neil's comment - often PCV blockage is the culprit, check it out.
I did the rubber glove test and it didn't blow up I had to replace the intake seal 2 years ago as to the PVC being done I can not say if it's ever been done I bought it used in 2011 with 148k on it has 182k now I noticed the timing belt was done at 67k miles(what was marked on the cover) The seal is leaking pretty good now I have been procrastinating on fixing it, however, i think the time has come to much crap behind cap causing misfires. I bought the OEM Volvo seal.
Tom Hood
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
115,000 Miles on a timing belt? I wouldn't bother fixing the seal. lol
The last seal I replaced sent me to the ER. Removal tool slipped and I banged my elbow on the inner fender well. Ouch!!! I thought that swelling would NEVER go down. lol
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I cringed just looking at that picture... Ouch!
