850 turn signal switch replacement
Been thanked: 504 times
Post by cn90 »
I have a $1M dollar question: can the hazard switch (located below the Radio) fail in such a way that the hazard function works (all 4 lights at 4 corners blinking) but the "Turn Signal" function inside the hazard switch fails?
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
cn90 wrote: 16 Apr 2017, 20:28 I have a $1M dollar question: can the hazard switch (located below the Radio) fail in such a way that the hazard function works (all 4 lights at 4 corners blinking) but the "Turn Signal" function inside the hazard switch fails?
Absolutely - It's hands down the most common way that they fail.
Teddy1975
Year and Model: 2007 V50
Been thanked: 7 times
Post by Teddy1975 »
With all electronics inside the hazard lights switch, I'd say yes.
Have a look at this: https://volvo850wagon.wordpress.com/201 ... -relay-pm/
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Has thanked: 1613 times
Been thanked: 4075 times
I've got a bunch of free ones as Evan paid me a free one forward. Pm me and I'll find and ship
Catch me before I'm on travel to nasty parts of world this week, though, if you are in a hurry
Post by cn90 »
Thanks abscate, I have a junk yard nearby, I will go there today and pick up BOTH the turn signal assembly + the hazard switch.
Thanks for the offer though!
The posts by BEJinFbk and Teddy1975 seem to contradict each other.
My review of the electrical diagram shows that:
Battery ---> Ignition Switch ---> Fuse #27 ---> Hazard Switch ---> Turn Signal Stalk ---> R or L turn signal lights.
YELLOW arrows show the path from battery ---> Turn Signal lights.
See diagram below:
Teddy1975
Post by Teddy1975 »
cn90 wrote: 17 Apr 2017, 07:11 The posts by BEJinFbk and Teddy1975 seem to contradict each other.
I'm not sure why, you'd think so. I'm fully agreeing with BEJ :)
As you say, the power runs through the hazard switch assembly on the way to the signal lights with a branch out to the turn signal stalk. So a problem with the circuit board in the hazard switch can cut the flow of power to the stalk = turn signal not working while hazards work fine.
/Teddy
Post by cn90 »
Teddy1975,
I am thinking problem with Connector 24/13, yellow arrow ---> Turn Signal Stalk.
This explains my symptoms.
This is b/c if you look at the Hazard Switch, the power supply for the hazard switch and the wire (GN-R) that feed the Turn Signal is the same.
So the "break" has to be downstream of the hazard switch.
Post by cn90 »
Thanks to jblackburn, he just updated the other thread, the problem (per jblackburn) was the Ignition Switch.
viewtopic.php?f=1&t=15383
Has thanked: 312 times
Been thanked: 818 times
Wow, you already fixed it? Now *that* was fast!
Was it the original electrical portion, or had you changed it already?
you need advanced equipment to test the turn signal switch - see here
Screen Shot 2017-04-17 at 4.03.27 PM.png (1.18 MiB) Viewed 905 times
Careful study of the waveform reveals why the cruise was inoperative
