Finally got to the bottom of the code on my donor car
Took it to a indi shop that specializes in Volvos, connected it to a smoke machine at the gas tank cap. Could not get smoke to the engine. Started disconnecting the main line going back to the tank and the problem ended up being a blocked roll over valve. Blow out the valve with air pressure and it passed the forced OBD2 unit test. I doubt I would have ever found that.
98 v70 NA P0455 - my most loyal friend
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- Been thanked: 4068 times
Where's your poem, Robert?
We have replaced all the hoses and spent 800.00 in parts for a air mass meter, and throttle body part and the peddle position sensor not sure these parts have anything to do with this code but we are at a loss as to why this code keeps coming back??? Thoughts or suggestions?
- Been thanked: 504 times
You need to find a better mechanic.
P0455 is EVAP code, which means the there is an "air leak" in the fuel system.
Very often, it is the broken hose above fuel tank, a $10 fix.
Also search for "J-Hose".
Search forum for "P0455" and you will see some threads on this topic.
Where are you Rhonda? Might be a forum member nearby, or a good mechanic rec. who can help you, Rhonda, get the right part....( ok , that was bad)
98v70dad
- Year and Model: 98 V70
Oddly, mine turned out to be just the seal on the gas cap. Early on I replaced the cap with a new cap from the dealership (expensive) so I never suspected it. It had a very very soft and small sealing ring. Out of desperation I bought a generic cap from carquest, removed the seal and put it on my original OE cap (I had saved it). I also inspected the filler neck and carefully burnished out a deep scratch in the sealing surface. Afterwards - no more PO455. It was my happiest day of 98 V70 ownership. It hasn't returned (yet).
- 1238 Views
Last post by clifford06
- 945 Views
Last post by FireFox31
- 576 Views
- 15 Replies
- 2231 Views
- 480 Views
