Whining Noise Topic is solved
- Has thanked: 316 times
- Been thanked: 531 times
Oil cooler thermostat... interesting. I've had mine off quite a few times, and I really didn't notice it before I took it off the first time.
kaneelschep
- Year and Model: '96 850 2liter t5
Did anything come out of this?
since a short time I have exactly the same whine that bmdubya1198 describes.
and it definetely also comes from the powersteering pump or that neighbourhood.
I read of more people having it. Even after replacing pump and tensioner/roller.
I never touched the oil cooler.. And that is situated lower right?
The oil cooler thermostat is located under the harmonic balancer. A little box with the two oil cooler lines going into it.
I actually removed my serpentine belt a couple weeks ago and started it cold to see if the noise was still there, and sure enough, it was. That's pretty much all the reassurance I needed to tell it's the thermostat making that noise.
- 2446 Views
Last post by Ou2mame
- 758 Views
- 9 Replies
- 2839 Views
Last post by Baptiste1106
- 9 Replies
- 4758 Views
Last post by plafratt
- 1554 Views
Last post by Stephent
