850 rear end restoration
Covert
Year and Model: 1997 850
Post by Covert »
So 200k later the back end of my 850 is very tired.
So decided to do a bit of a restoration.
Still lots to do , going to replace the exhaust and stone chip the rear end while ive got it all apart
Basically replacing all bushes , shocks , springs , brakes , handbrake cables etc etc
Does anyone know what size the rear brake pipe union that goes to the rear caliper is?
Thanks in advance Mark.
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Wow, very impressive work. I'm sure the bunnies would agree with that too :lol:
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Covert
Post by Covert »
Ha yes he is a big fan!
Covert
Post by Covert »
Some more pics
Rear spring top plates were a bit rotten !
New hubs, fitting kit for brake shoes , still many more parts to order
Ordered this today
http://www.partsforvolvosonline.com/pro ... ts_id=8283
Covert
Post by Covert »
These are the buggers im on about need to know what thread / size they are as im going to have to replace most of the brake pipes as well.
850 LPT
Post by 850 LPT »
You're not fooling around, aren't you?
That rear axle looks better than when it left the factory!
Your brake lines are all standard European fare, the nuts are M10 x 1.0 fine thread and the lines are 4.75mm with DIN/ ISO flare.
This is a good reference:
http://www.fedhillusa.com/webnuts/common%20flares6.pdf
Covert
Post by Covert »
Awesome thanks matey , that's really helpful.
Well my thought is do it once do it well , helps that it's a winter car so can take my time and do it right. Next summer is a rebuild on the front end
chrafael
Year and Model: 1998 v70 GLT
Been thanked: 10 times
Post by chrafael »
Nicely done. I did mine in a similar fashion about a year ago and never regretted it. What kind of paint is that? Mine is starting to peel off. My steel pieces appeared to be hot dipped galvanize coated but I painted them anyway. If I had to do it again I would probably use a good undercoating instead.
Has thanked: 1505 times
Been thanked: 3818 times
Im only an hour west of Northampton in NY - Ill pop in and have a butchers this weekend, covert...
Covert
Post by Covert »
thanks Chrafael , mine seemed to be galvanised too although I had them shot blasted as they were covered in 20 years worth of crap .
im using this paint.
https://www.smithandallan.com/products/ ... l-colours/
ive used it in the past for lathe/milling machine restorations and it seems to hold up well.
although grey wasn't my first choice I had a large tin of it so that's the colour it turned out lol.
thanks for the offer Abscate but im in Northampton in the UK~! still welcome in for a brew anytime you are passing! :D
seem to get better responses to questions on this forum to "other" Volvo forums so I tend to use this more .
new rear discs turned up yesterday , and got all the brake pipes changed to new, waiting on rear suspension kit , rear shoes .
and the shot blaster to tell me he has finished my delta mounts .
all the best Mark.
